Removing upper panel (center console)... How the hell?
Old May 12, 2005 | 05:40 PM
portero23's Avatar
I'm installing the Neo Ion but I can't get the upper panel off (the panel around the shifter)! How do you "detach clips A"?!?! I've tried the electrical tape-wrapped screwdriver, but I feel like I'm going to snap something!
Somebody clue me in, it's probably something really really simple right? because it's not explained in any DIY's I've searched through...
-P23
Attached Thumbnails Removing upper panel (center console)... How the hell?-page1.jpg
Old May 12, 2005 | 08:17 PM
RX8-CARL's Avatar
Put a finger in back of hand brake and simply pull up, may help if you have gloves on, and pull on the gaitor ring at the same time.
Old May 12, 2005 | 08:45 PM
kachud's Avatar
Mad Scientist
I found the easiest thing is to pull up on the shift boot. It will free the front of the piece and the rest will be easy to remove.
Old May 12, 2005 | 09:17 PM
StealthTL's Avatar
Metatron
I'm with Kachud.....
....give it the 'boot'!
Grab a good wad of leather on both sides and reef! The only way you can break clips is if you don't lift straight up.
S
Old May 12, 2005 | 09:45 PM
snap-on's Avatar
Put a couple of layers of masking tape on the silver portion of the console and pull straight up. It does take some effort so don't be shy.
Old May 12, 2005 | 10:19 PM
adrian-1's Avatar
Ex- member.
Pull straight up.
Attached Thumbnails Removing upper panel (center console)... How the hell?-img_1946.jpg   Removing upper panel (center console)... How the hell?-img_1949.jpg   Removing upper panel (center console)... How the hell?-img_1950.jpg   Removing upper panel (center console)... How the hell?-img_1951.jpg
Old May 13, 2005 | 02:22 AM
portero23's Avatar
Sweet...thanks guys! Now see my trials and tribulations with the Neo Ion...
-P23
Old May 14, 2005 | 02:57 AM
truemagellen's Avatar
Attracts tree branches
ummmm :p
Old May 15, 2005 | 08:14 PM
adrian-1's Avatar
Ex- member.
Talking
Stick finger into the hole and wiggle.......
nadodave
Aug 28, 2019 05:55 AM
vapor2
Jul 9, 2016 07:35 AM
05rx8mazda
Nov 28, 2015 09:42 AM
CARBONRX-8
Oct 5, 2015 03:46 PM
