How to remove mazda embrem on the trunk.
Old May 9, 2005 | 01:58 PM
Sweet's Avatar
Hello,
Can anyone tell me how to remove these emblem off from the trunk? It is a pain in the rear end when I wax the car. Thanks.
Old May 9, 2005 | 02:19 PM
Sweet's Avatar
Originally Posted by abbid
I dont know what am Embrem is.... :p
The two emblems on the left and right will come off with some dental floss or fishing line, going between the emblem and the car. The residue can be removed with goo-gone. The middle mazda emblem has 2 prongs that go into the body, removing those would require bondo filling, sanding, and repainting.
Yes, I just want to remove "Mazda" and "RX-8" emblem. My friend told me that he can use your techni on his WRX so I will do the same on my car as well. Thanks again for the tip.
Old May 9, 2005 | 02:31 PM
th1rd3y3's Avatar
05 STi/05 Titan
I thought the mazda one was held on with prongs too :o all this time I've had it there and wanted it gone
Old May 9, 2005 | 02:33 PM
Outlaws eXtreme's Avatar
2010 Prius - Miss the 8
By removing that "Mazda" squiggle emblem, you will have to use bondo, fill up the hole, repaint to match...et cetc.
Old May 9, 2005 | 02:34 PM
mikeb's Avatar
100% Italian
which is not cheap^^^^
may cost a couple hundred
Old May 9, 2005 | 02:35 PM
th1rd3y3's Avatar
05 STi/05 Titan
Originally Posted by Outlaws eXtreme
By removing that "Mazda" emblem, you will have to use bondo, fill up the hole, repaint to match...et cetc.
So only the RX-8 one can be removed without filling holes as I originally thought? The other 2 require bondo/sanding/painting?
Old May 9, 2005 | 02:37 PM
You can remove the words out... but not the emblem symbol without having to do some bondo repaints.
Old May 9, 2005 | 02:43 PM
th1rd3y3's Avatar
05 STi/05 Titan
Well crap. Oh well, I guess I'm going to remove those this weekend then
Old May 9, 2005 | 02:45 PM
subduedracer's Avatar
Realtor1
So, which is it? Both will come off, or just the RX8 emblem?
Old May 9, 2005 | 03:03 PM
Phlash's Avatar
Go Speed Racer, Go!
They both can come off, but the Mazda and Mazda Logo leave holes behind. Now, an option is to remove Mazda and move the RX8 from the right side to the left. Positioned correctly, it can cover the holes left over from the Mazda badge. That's what I did
Old May 9, 2005 | 03:06 PM
th1rd3y3's Avatar
05 STi/05 Titan
So in other words they both "come off" but the mazda one will leave holes. Which is exactly what I thought from the beginning. Now I'm sad
Old May 9, 2005 | 03:29 PM
Parmer8's Avatar
For more clarification, the Mazda symbols ( front and back ) will require bondo and repaint if you want them removed.
Old May 9, 2005 | 03:35 PM
apotocki's Avatar
OK...Let's try and make this easy.
MAZDA - will leave holes
Middle emblem - will leave holes
RX8 - no holes
Is this right?
Old May 10, 2005 | 01:47 PM
Sweet's Avatar
RX8 - no holes
Is this right?
Yes, that is correct. I will leave mine alone. I think I will remove them and wax area under the emblems and put them back in place. That will keep me busy for about 1/2 hour.
Old May 10, 2005 | 02:24 PM
Sweet's Avatar
Sweet, how do you know if thats correct, didnt you ask the original question? :p
I played with the emblem last night and pull out that "Mazda" emblem and it does leave holes on the trunk. So it is not glued. The RX-8 letter is the one that glued on.
Old May 10, 2005 | 02:45 PM
8is>enuff's Avatar
Bland
Did anyone say dentar fross?
Damn, I hate showing up late.
Old May 10, 2005 | 10:51 PM
LiveBlues's Avatar
Personally, I like for people to know what kind of car I am driving.
rotorocks
47
May 11, 2016 03:23 PM
fullsmoke
Nov 24, 2015 04:09 PM
Junirol
Sep 22, 2015 06:02 AM
RenzoRx-8
Aug 25, 2015 10:29 PM
D13
Aug 22, 2015 11:42 PM
