emanage/etool help
Old May 7, 2005 | 10:40 PM
youngpit's Avatar
emanage/etool help
I am sitting in my car trying to up load this map that jeff put out and the correspond its has been like 15 min and the status bar moved 1 time. cant seem to updat anyting what am i doing worng. i have tryed with the car off, ignition on, emanage pluged in and unpluge. i am getting anoyed i can even spell i am so\
Pi--ed
Old May 7, 2005 | 10:58 PM
SOftware installed properly....first place to look when not corresponding...both the cable software and the Support tool
E-manage on ( ignition on)
Old May 8, 2005 | 12:46 PM
adrian-1's Avatar
Ex- member.
Make sure it set up on the correct COM port. I had to change mine on the emanage software to match up with my laptop.
To check which COM port the laptop is using:
Right click My Computer -> Properties -> Hardware Tab -> Device Manager -> Ports
See which COM port your cable is on and then setup the emanage software to the same one. There's a tab where you can select COM1 thru COM6.
Old May 8, 2005 | 01:08 PM
youngpit's Avatar
thank you for all your help i figured out that the cable is no good thanks to my daughter who wanted to it into her computer and broke one of the pins off....
Old May 8, 2005 | 02:51 PM
adrian-1's Avatar
Ex- member.
missing pin? That will do it.
Tell me how the new map works out.
I'm waiting to get my CZ CanScan and do some datalogging and see which map works better for me.
