Random Tech High-Flow Cat Install
Old May 5, 2005 | 12:49 AM
Bones's Avatar
I decided on the Random Tech Cat & Resonator as I wanted something that would improve flow over stock, but not be too loud (wife factor).
The Random Tech comes in two basic parts the Cat and the Resonator as well as bolts and seal.
I took some pics before I installed.
Attached Thumbnails Random Tech High-Flow Cat Install-cat-resonator1.jpg   Random Tech High-Flow Cat Install-high-flow-cat1.jpg   Random Tech High-Flow Cat Install-cat-internal1.jpg
Old May 5, 2005 | 12:59 AM
Bones's Avatar
The install was more of pain than I thought it would be, in that it was difficult to get all the seals lined up just right and tight. Things would tend to shift (gasket, alignment) while tightening bolts and I would have to start over.
Here are some pics after installing. The bronze color comes after running it for a few days.
The probem area was the connection in the second picture between the Cat and the Resonator. However, I was enventually able to get a good seal.
Attached Thumbnails Random Tech High-Flow Cat Install-installed-cat.jpg   Random Tech High-Flow Cat Install-cat-resonator.jpg
Old May 5, 2005 | 01:08 AM
Bones's Avatar
The Results:
The Random Tech unit is not much louder than stock with the stock muffler on. My wife didn't notice the lower pitch or slighlty louder growl until I pointed it out.
The performance response, especially as the RPM climbs is improved. I had her in the car while testing it out and she said she noticed that it felt like she was being pushed back in her seat more.
Fit and fittment is good overall. However the resonator comes fairly close to a bolt/nut on the underside of the car and will occasionally (1 out of 10 starts) rattle against it when I start out from a dead stop.
Everything else on the car is stock, except a green filter and a Canzoomer stage 1 ECU, which is not tuned - yet.
Old May 5, 2005 | 01:11 AM
Lock & Load's Avatar
NO SUCH THING AS AN EASY INSTALL looks good seems that the 02 sensor to the cat is at a better position than the stock exhaust , NOT AS LOW . :D
cheers
michael
Old May 5, 2005 | 07:22 AM
DreRX8's Avatar
How much was it?
Old May 5, 2005 | 07:23 AM
MadDog's Avatar
Consiglieri
yeah, and where? I wonder how it compares to the RP cat...
Old May 5, 2005 | 08:10 AM
XeRo's Avatar
Normality is Obscene
i believe Canzoomer is the only one that can get this..it was kind of an exclusive build for him...at least this is what RT had told me about a year ago...
Old May 5, 2005 | 09:05 AM
Bones's Avatar
I looked around but the only place I could find the Random Tech cat & resonator was from Canzoomer's website. The cost I paid was $626 including shipping.
I like the more gradual taper of the Rotary Performance cat, but I ended up going with the Random Tech as I didn't want to hassle with buying a separate resonator and having a shop weld it on, plus weld in the hangers for the RP.
jay_tibo
22
Sep 13, 2016 08:10 PM
Kanthinar
Dec 21, 2015 01:24 PM
RenzoRx-8
Aug 25, 2015 10:29 PM
dbarber
Jul 25, 2015 01:34 PM
AussieGray
Jul 16, 2015 03:58 AM
