What is this?
Old Apr 25, 2005 | 10:29 PM
bmcc49er's Avatar
What is this?
I don't have a pic and i have washed my car so much i can't believe i never saw it. In the back below the bumper in the fake mesh there is a little square. Pull it open and it looks almost like a water connection. Obviously not a mechanic and i am curious what its for?
Old Apr 25, 2005 | 10:32 PM
RX8-CARL's Avatar
It's for your towing eye I think.
Look in the manual it shows you there.
Old Apr 25, 2005 | 10:33 PM
Im_DANomite's Avatar
I love GOOOLD
tow hook?? i've never checked it either.
Old Apr 25, 2005 | 10:34 PM
rodmeister's Avatar
I believe those are the holes for the tie down bolts. My square has always been missing, and Mazda refuses to give me one.
Old Apr 25, 2005 | 10:38 PM
bmcc49er's Avatar
Ahh, of course. That is exactly what it is. Wow, I would definitely raise hell about them replacing that. Very noticeable if the square is missing.
Old Apr 25, 2005 | 10:39 PM
I love GOOOLD
just go to the dealership, walk around and pretend like you're looking to buy an RX8 and then just steal one off the new cars!!! muahahaha, yes, i'm shiesty. so what!?!?
Old Apr 25, 2005 | 10:40 PM
Nemesis8's Avatar
Bigus Rotus
Yes, tie down bolt/hooks for the Ocean liner, and Mazdaspeed aftermarket tow hooks.
Old Apr 26, 2005 | 11:51 AM
RenoIV's Avatar
Rotary powered since 1988
Try this link to Finishline performance. Appears you should have at least two tie down plugs depending on the year of your 8.
http://www.finishlineperformance.com...01-05-1472.pdf
Old Apr 26, 2005 | 12:06 PM
fredw1's Avatar
There is only one, on the right side, which seems to be an unlikely place (and number) for a tie down.
Old Apr 26, 2005 | 12:10 PM
fray's Avatar
Look in the black toolbox in your trunk. The tie down hooks are in there. (Or at least they are on my RX-8)
Also the manual says something about this as well.. basically if you ever had the car flat-bedded, I've been told you need to show them to the driver or they could have problems properly securing the car (i.e. breaking something.)
Old Apr 26, 2005 | 04:53 PM
L8APEX's Avatar
Smooth Criminal
On cars that sit lower to the ground, such as ours, it is a good idea to use these when putting the car on a flatbed, because they usually just strap a hook around some solid point under the car, not really caring what will happen, and start pulling. This would cause the steel cable to pull tight against the rear diffuser, causing damage.
I never noticed the one in the front though, thanks nemesis for pointing that one out.
