Some Basslink Install Questions
Old Apr 25, 2005 | 11:11 AM
RX8-4me's Avatar
San Antonio TX
Arrow Some Basslink Install Questions
Hi everyone,
I finally got a basslink to intall into my 8. I have already run the Power/Ground thru the car and I have a couple questions for people who have done this.
1. Where did you tap into for the Remote Turn On? I read on the forum of someone able to tap into the harness at the Bose amp and said to refer to the wire diagram that is posted on the forums, but I have searched and can not find it.
2. Where did you place it in the trunk? I have seen pictures of it in the corner, which is where I would like to put it, but I'm hoping someone can tell me how they secured it.
3. When tapping into the spearkers, did you not use a LOC, and just go from the speaker lines to the high-level inputs on the basslink and let it do the conversion?
Thanks,
John
Old Apr 25, 2005 | 11:24 AM
khtm's Avatar
I like rusty spoons
1. You can tap into the preamp input into the amp that powers the rear speakers (this amp actually powers ALL the speakers, but it's located in the trunk under the rear speakers).
The wire you want is the pink and black wire on the top edge of the BLACK connector. You can scotchlock it or use a wire tap connector, but this is what I did: just peel back the plastic from the wire, spread the wires apart so there's a hole in the middle (don't cut them), stick your remote turn on wire in between the wires you pulled apart, wrap it around the wires, then tape it up.
3. I used the same preamp input to get the line-in input to my amp (this was a regular amp, not a basslink, but hopefully basslinks don't just have speaker-level inputs).
(shamelessly stolen from G8Rboy...his instructions are awesome :D)
That pic should explain what you need to do. I did the same signal-stealing procedure as described above. But I cut the ends off an RCA cable to do this. The side with the red plastic is RIGHT. The wires around the interior plastic are GROUND. The wire in the middle is the SIGNAL wire.
Good luck!
Old Apr 25, 2005 | 05:43 PM
RX8-4me's Avatar
San Antonio TX
Thanks for the reply. I found G8Rboys install post, but all the pictures were missing. Do you have them saved on your PC?
mr. GrandGame
Sep 9, 2025 10:41 PM
Pelleilee
Sep 29, 2019 10:07 AM
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
dancingdan42
Aug 19, 2015 09:29 AM
MolecularConcept
Aug 5, 2015 04:43 PM
