factory torque specs needed...
Old Apr 24, 2005 | 04:44 PM
SharkDiver's Avatar
ZoomZoom
Question factory torque specs needed...
Hey all,
I did a search and found what I needed but the link was dead.Anyways Im installing some lowering springs tomorrow and need the factory torque settings if anyone has them for the front and rear.
SHark..
Old Apr 24, 2005 | 08:04 PM
adrian-1's Avatar
Ex- member.
Sorry about the dead link. I just fixed it.
https://www.rx8club.com/showthread.p...t=torque+specs
Attached Thumbnails factory torque specs needed...-front-suspension.gif   factory torque specs needed...-rear-suspension.gif
Old Apr 24, 2005 | 08:08 PM
SharkDiver's Avatar
ZoomZoom
Thanks.I cant wait to start installing these..
Old Apr 24, 2005 | 08:14 PM
adrian-1's Avatar
Ex- member.
I forgot to mention the numbers are the order your supposed to remove them.
Also, check the link for high resolution .tif files if you can't make out the numbers.
Have fun.
Old Apr 24, 2005 | 09:20 PM
SharkDiver's Avatar
ZoomZoom
Which # is the ft-lbf number?
Example:The numbers for the Right strut bolt on top says (3.21--4.70, 23.2--34.0) What number is the ft-lbf?34.0?
Thx,Shark
Old Apr 25, 2005 | 07:52 AM
adrian-1's Avatar
Ex- member.
Thx,Shark
Bottom right on both pages is the units.
Numbers outside the parenthesis are N*M
First set of numbers in the parenthesis are kgf*M
Last set of numbers in the parenthesis are ft*lb.
They give you a range to pick from. I used the higher number just to be safe. So, yes 34.0 is correct.
Old Apr 25, 2005 | 09:29 AM
SharkDiver's Avatar
ZoomZoom
Thats kinda what i thought but I didnt think they gave ranges when you have to use a torque setting.. :o oops
duworm
Oct 1, 2015 04:57 PM
Quiggs321
Sep 30, 2015 05:34 PM
FubarI33t
Sep 28, 2015 08:45 PM
Stubbs
Sep 27, 2015 04:06 PM
