Brake fluids
Old Apr 22, 2005 | 10:02 PM
Lock & Load's Avatar
Brake fluids
Confused i purchased vavoline heavy duty brake fluid for disc brakes drum brakes and clutch systems .
SAE JI 703 - FMVSS STANDARD NO .116 DOT3 WHICH IS RECOMMENDED IN OUR RX8 MANUAL FOR THE AUSTRALIAN CARS
reading the fine print it also says .in red ... Not recommended for ABS systems ????
Can anyone explain the difference .........whats going on .
cheers
michael
Old Apr 22, 2005 | 10:41 PM
xxup's Avatar
According to their website it looks like you need SynPower brake fluid.. See http://www.valvoline.com.au/products...&category=FCQK
I suspect that it has to do with all those little seals in the ABS valve unit.. I don't know what the one on the RX-8 looks like on the inside, but the Honda prelude in the mid-80s had lots of little rubber seals..
Old Apr 23, 2005 | 12:23 AM
takahashi's Avatar
I am 100% sure it is DOT 4 that is used in our car. I have check with Melbourne City Mazda, Victoria's Mazda Australia quarter and another dealer (Brighton) before I put my Motul RBP 600 (which is DOT 4 based) in.
I think DOT 3 and DOT 4 are the same compound but just DOT4 better than 3. However, I think DOT 5 is totally/partially difference and it is not good for the lines we are using (this info is from Motul). RBP 600 has the highest rating and it is DOT 4 based. PERFECT
Old Apr 23, 2005 | 02:32 AM
XXUP
Sorted out the vavoline brake fluid mystery swapped it for the synpower $6.99
looks like i need to take my glasses next time and read the fine print
Taka i am sure you are using the best product available as allways AT $$$$
I am getting Royal Purple oil for my differential and my transmission apparently its better than Redline oil , the only downside is they want you to buy it bulk , but i managed to get a 6 litre pack to try out at cost he he he .
cheers
michael
theblinkof
Oct 4, 2023 05:24 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
XianUnix
Sep 29, 2015 03:48 PM
