Removing Front Grille?
Old Apr 20, 2005 | 12:38 PM
cretinx's Avatar
Hey guys,
I've got a turbo now, and the intercooler is all hidden behind the grille - so the good side is that it still looks stock, but the problem is that its not getting as much cold air as it could with all that plastic mesh in front of it - can this stuff come out? Is it easy?
Old Apr 20, 2005 | 11:02 PM
cretinx's Avatar
thanks for all the replies guys.
Old Apr 20, 2005 | 11:18 PM
ShowandDriftRX8's Avatar
The 8 is back
From looking at the stock bumper you will need to cut it out with a rotary tool most likely. It shouldnt be too hard. You should look into getting an aftermarket kit to maximize the airflow though since the stock bumper wasn't made to incorporate a front mount.
Old Apr 21, 2005 | 08:48 AM
EZZY's Avatar
cry me a river...
have to take the front bar off to remove the grille.
you can always trim the grille and mesh it
Old Apr 21, 2005 | 11:32 AM
Parmer8's Avatar
1. Get a dremel and trim out the interior mesh. The outer trim will get a bit out of shape because the interior plastic supports the shape, but that's not problem to fix. Get a big enough sheet of mesh and form a similar shape for the interior.
2. Spraypaint the styrofoam bumper insert black. Make sure you use a primer first or the paint wont stick and will end up eating the foam.
Old Apr 21, 2005 | 01:24 PM
cretinx's Avatar
thanks guys.
I don't think I'll mesh it because I want it exposed
The intercooler occupies the EXACT space as the stock opening, so it'll be perfect if I get it open.
Old Apr 21, 2005 | 01:48 PM
Intrigue 8's Avatar
Take some pics when ur done
Old Apr 21, 2005 | 02:43 PM
ttt's Avatar
ttt
yes please
yapakanichi
Sep 17, 2015 04:23 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
rxwilly8
Sep 2, 2015 02:42 PM
