Crossover placement
Old Apr 19, 2005 | 01:03 PM
TooBIG's Avatar
Crossover placement
Where is everyone putting the crossovers for the fronts ?
I am ordering Bostons and the crossovers are huge.
Can I just put them in the trunk next to the amps or can someone
suggest a better choice ?
Thanks,
-B
Old Apr 19, 2005 | 03:44 PM
TRU681's Avatar
I originally mounted them in the doors but I changed my 2 sets component speakers & got a bigger crossover(2 corssovers together forming one).Now I'm mounting them behind the rear seats in the middle area. I'm at work so no pictures right now or you can look for the picture in my other post in this same category( since every1 is doing it here's my custom audio/video system)
Old Apr 19, 2005 | 05:49 PM
TooBIG's Avatar
Thanks. I'll mount them behind the seats also.
-B
Old Apr 19, 2005 | 08:35 PM
vdelvec's Avatar
Boston Z6's?
Old Apr 20, 2005 | 03:15 PM
TooBIG's Avatar
Z6 at this point.
PRO60 maybe.. if my $$ runs low.
Old Apr 20, 2005 | 09:13 PM
vdelvec's Avatar
Make sure you have at least 150watts going to each if you go w/ the Z6.
Old Apr 20, 2005 | 11:08 PM
TRU681's Avatar
Here's the picture of where I'll be putting my big crossovers.There's going to be 2(one for each set of components) & they will be stacked.
Old Apr 21, 2005 | 10:49 AM
TooBIG's Avatar
OUCH.
I was going to order a JL Slash 300/4 for the fronts/rears.
That is only 75W rms each.
They take 140W rms.
So maybe I will get the Jl Slash 450/4.
150W rms x2 for the fronts and 75W rms x2 for the rears.
Thanks,
I'll get that amp instead.
-B
Old Apr 21, 2005 | 11:05 AM
TooBIG's Avatar
They are huge. Can't wait to see the pics of your completed system.
-B
Old Apr 21, 2005 | 12:31 PM
mitchfried's Avatar
I have the Z6's, with a JL 300/4 bridged to 2 channels. You can play them so loud your ears will bleed and your brain will liquify. I have the crossovers in the trunk in the space where the spare would normally go, along with a JL 500.1 for the sub. The two amps are exactly the right size for the space. I'll try to dig up some pictures. Right now, I'm waiting for a new JVC headunit to mount in the glovebox.
Old Apr 21, 2005 | 12:40 PM
mitchfried's Avatar
Here's a picture of the amps and crossovers in the spare tire well:
Here's the cover that goes over the amps:
And the subwoofer on top of the cover
Old Apr 21, 2005 | 01:07 PM
TooBIG's Avatar
Nice mitch. Thanks for the info and pics.
I am going to get the 450/4 and 500/1 for subs.
I'm not sure if I want to use the well like you did, or the area under the rear deck.
Questions:
What gauge wire did you use from the xovers to the fronts ?
And what did you have to take apart to get the wires into the door driver and tweeter ?
Does the whole door panel need to be removed or just the speaker cover ?
Any advice you can give me or things to look out for ?
Thanks,
-B
Old Apr 21, 2005 | 02:01 PM
mitchfried's Avatar
I had the install done by Sound Advice. I know that the inside of the door was removed, and that they managed to snake the new wires through the wiring harness that goes into the door from the car.
The awesome thing about the Z6's is that they can handle in excess of 200 watts a piece. I originally bi-amped the speakers (75x2 to the woofers, and 75x2 to the tweets) when they were in my Mazda6, but the woofer needs more than 75 watts, and 75 watts is way too much for the tweeters. So don't bi-amp, which means you don't need a 4 channel amp.
I had the tweets mounted where the factory tweets were. Boston recommends leaving the tweets on the woofer, but when I tried that with my Maz6, the sound stage was too low.
The Z6's are brutally honest and uncolored, so a bad recording will sound bad. Some prefer silk tweets because they mellow the sound. These speakers have lots of depth and you will be pleased. However, in that price range I've been told that DLS and Focals are excellent also.
Old Apr 21, 2005 | 02:25 PM
TooBIG's Avatar
I am going with the 450/4 because I am replacing the rears also.
So 150x2 for fronts and 75x2 for rears.
I have never heard Focals.. wonder if anyone around me sells them.
I'll check.
Thanks,
-B
Old Apr 21, 2005 | 03:04 PM
mitchfried's Avatar
Perfect. Do you really need rears? Using a sub-woofer?
Old Apr 21, 2005 | 03:17 PM
TooBIG's Avatar
It's a matter of want.. not need.. haha
Subs.. yes.
2 JL 10W3v2 D4
Old Apr 21, 2005 | 03:46 PM
TRU681's Avatar
Very true, rearfill is not needed in a small car.Also soundstage is better without rearfill.
Old Apr 21, 2005 | 03:49 PM
TRU681's Avatar
-B
Me too, it's been over 2 months now in the shop.Hopefully in couple more weeks.
Old Apr 21, 2005 | 09:44 PM
sfgr415's Avatar
TRU, this is Joseph from the stereo shop...was browsing RX8 club and noticed you were on here...I was talking to Peter yesterday and things are wrapping up on the fabrication side...pretty much the only thing left in the trunk is the piece where the capacitor sits...The rear deck had to be built up as well...Aside from that, I think the custom part is done with...
Old Apr 21, 2005 | 11:21 PM
TRU681's Avatar
Sup Joseph, I just hope it'll get done by the 1st week of May.I just talked to Peter today & he said he has preped & primed almost everything to get it painted.Hope he finishes the trunk by this weekend.After trunk's done then build the rear deck, PS2 in glove, Dynamat extreme everything, & finally wiring everything up.Hopefully in two weeks so I can go back to bodyshop to put on the Mazdaspeed kit before the photo shoot.
zoom44
General Automotive
Nov 16, 2015 11:38 PM
ripigs
Aug 2, 2015 10:44 PM
ktec
Jul 29, 2015 01:17 PM
Lock & Load
General Automotive
Apr 21, 2006 12:15 AM
weekendwrench
Jun 2, 2005 07:33 PM
