no beeb or chime at redline
Old Apr 18, 2005 | 09:13 PM
billypsm's Avatar
I do not drive my car hard very often but I have wanted to hear the beeb. A couple of days back I rode it hard and reached 9500rpm and never heard any warning noise....I am a little hard of hearing, but my wife isn't and she couldn't hear it either. Now if my chime or beeb is inoperatve what's the best way to bring it up to the dealer so it can be fixed. I know they would probably say 9500rpm is not good for the car. Personally I think it is good for it from time to time. Ant thoughts?
Old Apr 18, 2005 | 09:15 PM
billypsm's Avatar
not ants....any
I didn't mean ants...I meant any....sorry my typing sucks
Old Apr 18, 2005 | 09:24 PM
beachdog's Avatar
If you don't hear too well, or even if you do hear well, it's easy to miss. It's not very loud and it's not continuous - just a short beep. If you had the radio on or the windows open you definitely won't hear it. You also passed it by 400 rpms.
-=Rowdy=-'s Avatar
It probably does work but it is very hard to hear at times. Some people cannot pick up certain frequencies with their ears. At times I have to second guess whether or not it went off and I have excellent hearing.
HardHitter's Avatar
Usually if you have your windows down you will not be able to hear the beep at all. With windows up and radio on mute I really have to listen for it in able to hear it. It's not that loud, and then add in the noise that the engine is making, it makes it hard to hear.
Today I accidently hit 10k in 1st gear and my car sort of died a little like the engine cutoff or something. This was the first time and I totally didn't mean to do that, but could this have caused damaged to my 8 or is it programed to "kill" a little so the engine doesn't blow up lol.
Old Apr 18, 2005 | 09:25 PM
theCATALYST's Avatar
In darkness I sleep.
You should not need any reason other then it not working. 9500 rpm is none of their business when it comes to fixing the audible BEEP, which, if it was working, you would have shifted at 9000, not 9500, right? It was put there for a reason, and if it doesnt work, then warrenty should fix it.
Also, just a side note. The beep is not very loud at all, at least mine isnt. It is hard to hear, especially if you have an aftermarket exhaust, or the radio on, or even with the air conditioner fan on high.
Old Apr 18, 2005 | 09:29 PM
BlueEyes's Avatar
It cuts fuel supply off so that your 8 doesn't blow up
Old Apr 18, 2005 | 09:35 PM
HardHitter's Avatar
Okay, so no damage to the car? I suppose if there was something, my CEL light would of came on. *Phew*
Old Apr 18, 2005 | 10:05 PM
JM1FE's Avatar
Here you go.
Old Apr 18, 2005 | 10:42 PM
spork's Avatar
Foolio
The only problem with taking it to the shop/dealer is they're going to drive and redline your car.
otherwise how do they know the problem exists and how do they know if they fixed it or not?
Old Apr 19, 2005 | 03:49 AM
Gomez's Avatar
Shifty Bastard.
Ther is only one beeper in your car. If the headlight on chime sounds, or the key reminder chime sounds.....then she's apples. You just can't hear the redline beep over the ambient noise.
Old Apr 19, 2005 | 06:30 AM
Mugatu's Avatar
Even My Dog Searches
you gotta love them beebs
Old Apr 19, 2005 | 06:55 AM
rx8wannahave's Avatar
Follower of CHRIST!!!!!!!
Yeah, I posted something like this before...it is hard to hear but it's there. Turn off the radio and close the windows and do a test....but this time try shifting at 9K instead of 9.5...lol
Note: Don't worry, I've hit 9.2K by mistake...it happens.
Old Apr 19, 2005 | 08:55 AM
Brandon's Avatar
Where does the beep come from? The radio speakers? I seem to remember once hitting redline with the radio up pretty loud and the radio cut out and was replaced by the beep, only the beep was quite a bit louder than normal.
Old Apr 19, 2005 | 01:03 PM
Gomez's Avatar
Shifty Bastard.
Its incorporated inside the instrument cluster.
Old Apr 19, 2005 | 01:24 PM
RX8PDX's Avatar
Is there any way to adjust the volume? Like a pullup resistor or something. Or can we just replace it with a louder buzzer.
I personally would like something extremely annoying and loud.
Old Apr 19, 2005 | 02:06 PM
L8tr's Avatar
Still Zooming...
Are you completely sure about that? It sounds like a different one to me (very very quite, almost dead).
Old Apr 20, 2005 | 06:47 AM
Gomez's Avatar
Shifty Bastard.
It's the same one....different frequencies and changed db levels, that's all. The redline beep is 1500hz and 75db....key reminder is 800hz, lights on chime is 1000hz, TPMS is 1500hz beeps, etc.
The redline warning is the loudest.....the others are at 67.5decibels.
Old Apr 20, 2005 | 08:09 AM
-=Rowdy=-'s Avatar
Ah-you're getting my brain to start working now....
How about a lovely female voice blurting out instead of the beep, "Please shift your stick sir to the next gear". Or how about incorporating a slight shock to the driver's seat when approaching said beep.
Old Apr 20, 2005 | 11:16 AM
valpac's Avatar
Ahead of its time
Yes, its true. Sometimes hard to hear. I have missed it on occasion, too. Could be Led pouring outta my speakers though. When I get rid of all ambient noise, and really listen for it, its there.
Old Apr 20, 2005 | 11:18 AM
valpac's Avatar
Ahead of its time
Originally Posted by -=Rowdy=-
"Please shift your stick sir to the next gear". Or ...
"I would touch your stick... (pause) now." :D
Old Apr 20, 2005 | 11:24 AM
Hornet's Avatar
Wut da F Y'all lookin' @!
Another thing is passengers pretty much never hear it even if you tell them to listen for it! The beeps location seems to be perfectly suited so that the driver can hear it (but of course as all of us know sometimes it's easily missed) yet it is faint enough to be unintrusive.
Old Apr 21, 2005 | 01:26 AM
ezrider55's Avatar
It is a weak beep.
Old Apr 21, 2005 | 04:51 PM
L8tr's Avatar
Still Zooming...
Thanx for the info Gomez!
Old Apr 21, 2005 | 05:04 PM
L8tr's Avatar
Still Zooming...
It still seems strange that I hear it loud and clear for the other functions, but not for redline. I usally have good upper freq range hearing (there's a chiller with a new pump 15feet from me, and its whinning is driving me crazzzzzzzzzzy, the other people back here don't here it). Even with the radio off and windows up I almost can't here it over my quite engine.
