Removing the VFAD unit
Old Apr 10, 2005 | 09:02 PM
mikefrombarrie's Avatar
Today, I removed the VFAD unit from the 8, to see if it would make a difference or make it worse. I was shocked in how well the car performed WITHOUT the vfad unit! The big difference is at low rpm, the car revs alot quicker now. I highly recommend getting rid of the VFAD unit. :o
From the negative side, idle is not as smooth. And the car is alittle bit noiser.
Old Apr 10, 2005 | 09:35 PM
Most reports of removing the VFAD from a stock car found poorer low end performance
Hope your experiment continues to work better than stock
Old Apr 11, 2005 | 04:21 AM
Mikelikes2drive's Avatar
the RB intake makes you remove the VFAD unit... ::shrugs::
Old Apr 11, 2005 | 04:23 AM
rotarygod's Avatar
The RB unit also flows more air than the stock system.
Old Apr 11, 2005 | 05:57 AM
RX4life's Avatar
In conclusion, get the RB unit.
olyrx7
Oct 26, 2015 09:23 AM
ShellDude
Oct 1, 2015 09:55 PM
Racingjunkie
Sep 29, 2015 05:05 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Stubbs
Sep 27, 2015 04:06 PM
