First oil change -- advice needed
Old Apr 9, 2005 | 05:03 PM
No More Oldsmobiles's Avatar
Custom User Title:
I'm going to schedule the dealer to do my first oil change, and I'd like some advice for things I need to ask them or things I might be overlooking.
(I know some of you do it yourself, but I want to get some things taken care of at the dealer anyway.)
Aren't there some specific washers you should ask them for in case you do it elsewhere the next time?
Also, I'm going to see if I can get the new dipstick.
Anything else I should be asking about?
Thanks.
Old Apr 9, 2005 | 05:39 PM
Aseras's Avatar
you might ask for extra crush washers, although you can reuse them a few times. you might ask is they are also draining the oilcoolers as well, or only the oil pan.
Old Apr 10, 2005 | 12:04 AM
ZoomZoomH's Avatar
Mulligan User
^most likely they just drain the oil pan, as that's teh 'standard' oil change procedure for the 8....
you should look into a Fumoto Drain Valve, then you'll *never* have to deal with crush washers ever again (and never have to lift the car up to change oil ever again) :D
Old Apr 10, 2005 | 01:56 PM
alleycatinheaven's Avatar
Where can I go to see this Fumoto Drain Valve?
Old Apr 10, 2005 | 02:21 PM
expo1's Avatar
He's as bad as Can
http://www.fumotovalve.com/
Before you leave the dealer check your oil to see if they over / under filled it.
Let the car warm up to full temp, that way you will notice if they spilled oil on your motor.
Old Apr 10, 2005 | 03:19 PM
snizzle's Avatar
Shakezula, the Mic Rula
do you use this? I'm wondering how well this thing seals up. What about the longevity? Will I have to buy another one after 5-6 changes?
Old Apr 10, 2005 | 03:52 PM
ZoomZoomH's Avatar
Mulligan User
^yes, i installed this on the very first oil change, it has been great, no leaks whatsoever
here is the FAQ from Fumoto's site:
http://www.fumotovalve.com/about.cfm
this is a very well built piece, i expect it to last beyond the life of the car :D
Skyl3r
Dec 2, 2019 04:51 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
robd1337
Jul 31, 2015 09:35 PM
RotaryRider
Jul 20, 2015 07:05 AM
