How much?
Old Apr 7, 2005 | 09:04 PM
nailman28's Avatar
How much?
I'm a newbie to rotary motors. been use to the v-8 torque. but anyways im getting a 04 rx-8 mt and i have been looking at the ssr turbocharger. and i was wondering how much boost you can run on this 2 rotary engine. i know that a tune is everything but i wood like the car to last atleast 50k or so. could i pull 11psi with stock seals. or what minor changes would i have to do to pull some better tq numbers. any advice would help. thanks
Old Apr 8, 2005 | 10:58 AM
guitarjunkie28's Avatar
port hacker
you could run 20+psi on stock seals if you tune it correctly.
i think you run out of gas somewhere in the 260-280 whp range, so if you want more hp than that, you might want to go with larger injectors, at least for the secondaries.
Old Apr 8, 2005 | 11:58 AM
StealthTL's Avatar
Metatron
V8 torque.....
You have to realise that 'torque' is just a number - a certain output at one particular rpm,
- a V8 doing 300 lbs-ft at 2k revs is putting out the same power as a small engine that does 150 lbs-ft at 4k.
- and if your motor can put out 150 lbs-ft all the way up to 8k, THAT is a lot of 'power'!
Good torque thread...
S
Old Apr 8, 2005 | 01:37 PM
Fanman's Avatar
Nobody has pushed their car to that level yet. Nobody wants to be known as the "first guy to blow his engine." There are people that are running around 8-9 lbs. of boost. On the recent RX Tuner magazine article they tested Philodox's (a poster on this board) RX8 with the Greddy turbo kit installed and he went from 130 lb.-ft. of tq to 193 lb.-ft. Not exactly large V8 type tq., but a definitely noticeable improvement across the midrange. I'm sure the SSR/SFR turbo unit will provide similar if not more tq #'s. If you get to over 200+ lb.-ft of tq in this car it would be far more noticeable in this car (about 3000 lbs.) vs. a Mustang (3500+ lbs).
Like GJ said, it's all about fuel management. SSR will sell (as an option) larger fuel injector & water injection kit as well. If you plan to go above stock boost you should get this. Also swap out the stock plugs for something a bit colder (1 or 2 heat ranges colder) to prevent detonation.
