Can anyone thinkof a way to adjust our idle RPM?
Old Mar 28, 2005 | 11:23 PM
brillo's Avatar
Go Texas Longhorns!
Obviously its computer controlled, but are there any tricks we could use to raise or lower the idle speed? I thought about adjusting the accelerator pedal slightly, but I don't know if that will work.
Old Mar 29, 2005 | 04:13 AM
RX4life's Avatar
hmm.. interested in this too.id like to raise it to like 1200 or something like that..
Old Mar 29, 2005 | 05:15 AM
crimson-rain's Avatar
I'm interested in this also.
Old Mar 29, 2005 | 09:21 PM
Magic8's Avatar
Mazda Mole
Curious on why you want to raise the idle speed, especially since it will probably eat up slightly more fuel.
Is it for smoothness?
Old Mar 29, 2005 | 10:31 PM
brillo's Avatar
Go Texas Longhorns!
yes, the main reason would be to smooth the idle. I doubt the fuel consumption would increase materially if you raised the idle by 50-100rpm. you'd have to be sitting at idle for most of your driving experience.
Old Mar 29, 2005 | 11:26 PM
zoom44's Avatar
techs can do it with the wds. ask one and point out the roughness. one of the mri's talks about doing it i think.
Old Mar 30, 2005 | 09:04 AM
brillo's Avatar
Go Texas Longhorns!
As I understand it, they can do while hooked up to the WDS, but they can't make it stick after disconnecting, thats how Snap-On explained it to me.
Old Mar 31, 2005 | 03:42 AM
RX4life's Avatar
hmm. thats shitty..
Old Apr 17, 2005 | 11:41 AM
flash it in
Old Apr 17, 2005 | 11:49 AM
jenkins-crew's Avatar
Getting the N flash helped raise mine a little.
Old Apr 17, 2005 | 03:04 PM
LiL BenNy's Avatar
Bubblicious? DEF.
i dont get how raising it would help.. mine idles at liek 2500.. and is rather loud i would think you would want to decrease it...
Old Apr 18, 2005 | 05:34 AM
RX4life's Avatar
2500!!! thats nuts..
you must get pretty crazy "unintended" off-line launches!! i think you should get it checked out...my car idles at 2K then drops from there on.. only when its wariming up...
Old Apr 18, 2005 | 05:51 AM
thuneon's Avatar
The idle revs you can set at the ECU, but the value is resetted periodly. I think the funktion is only for testing anything. 2500 ? Are you crazy ? Ask your clutch what it think about that ! 1.000 or 1.100 should be fine.
THUNEON
Old Apr 18, 2005 | 06:39 AM
Mine is the same as RX4life....you should get yours lowered.
Old Apr 18, 2005 | 09:32 AM
Labop's Avatar
maybe he's talking about the warm up period where it's up at 2.5k?
Old Apr 18, 2005 | 09:34 AM
Still kind of high don't you think?
Old Apr 18, 2005 | 10:46 AM
zoom44's Avatar
uh yeah idle rpm should be between 750 and 950. an idle 1k rpm or more is too high
Old Apr 18, 2005 | 12:23 PM
Labop's Avatar
No, I'm talking the first minute or so when you start her up. It stays up at 2.5k for a bit and then settles down to about 1k. You never noticed this? I've seen it on here before...
Old Apr 18, 2005 | 01:11 PM
RX4life's Avatar
nope.. my idle dont go above 2k....you car must be verrrrry cold.. hehe
Old Apr 18, 2005 | 01:44 PM
Mine goes from like 2k to about 900 after warm up.
RevMeHarder
Jun 1, 2026 02:30 PM
Forevermore
Sep 20, 2015 01:04 PM
RAE008
Sep 19, 2015 02:24 PM
DVerdeyen
Sep 13, 2015 11:19 AM
GARCIAC951
Sep 10, 2015 07:17 PM
