View Full Version : 18X8.5 18X9.5 offset 35 on rx8?
WanKeL FD RX-7
03-26-2005, 02:25 PM
will it fit ??? it is supposed to go on my dad's FD but we want to try them on the rx8, am i going to have issue with rubbing or things like that..
tires are 235 40 zr18 front, rear is 265 35 zr18
Max
army_rx8
03-26-2005, 02:41 PM
make sure the bolt pattern is the same i believe the 8 is 5x114 or something like that, not sure what the bolt pattern is for the 7. and for the offset you can use this http://toy4two.home.mindspring.com/offset.html
WanKeL FD RX-7
03-26-2005, 02:43 PM
rx7 is 5X114.3
WanKeL FD RX-7
03-27-2005, 09:32 PM
... i'm wondering if the offset will be fine? 35mm
Max
murix
03-28-2005, 01:36 AM
I am running Enkei RP03 35mm offset in a 18x8.5 w/245/40/18 on all four corners. That is the limit on what would fit. I am on a Mazdaspeed suspension with no rubbing.
http://www.murix.com/albums/RX-8/images/DSCN0109.JPG
http://www.murix.com/albums/RX-8/images/DSCN0110.JPG
http://www.murix.com/albums/RX-8/images/DSCN0111.JPG
army_rx8
03-28-2005, 10:53 AM
murix why did you go for teh 8.5" ide rims? they looks sweet. re-amemiya has teh same rims on their 8. loks great. but wouldn't 245/40/18's fit on the stock rims? i'm pretty sure a buncha' people on here have done it. don't get me wrong if i had teh money i'd get those rims or maybe some ro_ja by rays. :D ah if only my money tree would start growing.
jenkins-crew
03-28-2005, 10:57 AM
I have the 9.5 in the rear with 19s and everything is fine.
WanKeL FD RX-7
03-28-2005, 08:34 PM
cool thanks guys
jenkins-crew
03-28-2005, 08:59 PM
Anytime, glad we could help!
Put some pics up later :D
murix
03-29-2005, 02:29 AM
Because I could. ;)
I did in fact put those tires on the stock rims the first time around and they worked great.
These are a little wider, a little lighter, a little farther out to the edges, and a little better looking. Minor changes add up to a big difference when done right in my book.
slllygrl10
03-29-2005, 10:02 AM
That should fit
takahashi
04-04-2005, 04:31 PM
Thanks murix
That is the EXACT size I want to get, great stuff. Lower 30mm without problem. GREAT!
The size shot makes me drool and the rear shot makes me high :p. They are great price cf. the Volks. They are light too. I think it is in a range of 8.x kg. Have you weight it?
