what to use on these parts of my car...
Old Mar 24, 2005 | 12:46 PM
slinkyGirl78's Avatar
instead of running the risk of submitting too-vague of a question, or else using the wrong terminology, i thought this would be easier
what would you guys recommend i use on these indicated parts of my car? i just ordered 303 Aerospace Protectant- i am guessing i can use that on most of the parts, perhaps not the black indicated by #1... so what should i use on that?
the 303 says it's for vinyl and rubber and plastic, and comes with a lot of UV protection.
thanks!
Old Mar 24, 2005 | 02:20 PM
rxeightr's Avatar
M0D Squad -charter member
I use the 303 on all the external components you displayed, as well as the dash. Looks great & lasts a long time.
Old Mar 24, 2005 | 02:53 PM
awesome! good to know, thanks
Old Mar 24, 2005 | 05:09 PM
markd's Avatar
Lawyer in training :)
Rxeightr: I would think the 303 would wash off since it's supposed to be used for interior plastic/vinyl.
SlinkyGirl: Thanks for the neato diagram!
#1: I've asked about the b-pillar before (see https://www.rx8club.com/rx-8-show-shine-26/b-pillars-how-clean-them-42499/ ). I don't think I got a consensus answer, although I think hitting it with a Quick Detailer is a great idea.
#2: Not sure--I've never detailed the rubber trim!
#3: Many people use Mother's Back-to-Black. Personally, I use the clear liquid tire dressing stuff (Black Magic, etc.). It works very well on the rear under grill, on the mirrors, and in the front. Little tidbit: If you dress this plastic trim first before you wax the paint, it's a lot easier to take care of that excess wax that gets on the black plastic.
Old Mar 24, 2005 | 07:50 PM
scottmhr1's Avatar
I second the aerospace 303. It works great on the exterior plastic and rubber, tires too!
Old Mar 25, 2005 | 03:59 PM
markd's Avatar
Yes, but does the 303 remove the white spots caused by wax on the black parts?
Old Mar 25, 2005 | 06:37 PM
mrthundercleese's Avatar
RRDI M.C.C.
Nope, doesnt. Ive yet to try back to black (even though I have a bottle of the stuff.. im a bit lazy)
Old Mar 25, 2005 | 07:18 PM
scottmhr1's Avatar
To remove white spots I use Dawn and a little water with a soft toothbrush. the apply the 303.
Old Mar 25, 2005 | 08:36 PM
Cam's Avatar
Cam
this space for rent
I wax #1. No fingerprints with the wax.
I use NXT protectant on 2 and 3.
Old Mar 25, 2005 | 09:21 PM
markd's Avatar
Cam--Do you use NXT? I haven't thus far waxed the b-pillars b/c I was afraid that they might chalk up like the black plastic parts do. If you've done it with success, though, I must add that little detail to my regiment.
Old Mar 25, 2005 | 09:45 PM
porschegeorg's Avatar
I use Collinite #845 on the b-pillars and on the rear exhaust area of your
diagram. I never have wax-build-up problems on the black pillars...and the
protection is better than 303 (at least in my opinion).
I've also used #915 on the b-pillars, but I like the ease of the liquid #845 as
opposed to the paste #915.
georg
Old Mar 25, 2005 | 09:53 PM
markd's Avatar
How did I know you were going to say Collinite? :D
Old Mar 26, 2005 | 02:22 AM
Cam's Avatar
Cam
this space for rent
Yes, I use NXT wax, and with no problems.
Old Mar 26, 2005 | 12:47 PM
bmcc49er's Avatar
303 says its for leather also. I use the NXT detailer on the door jambs, etc. and back to black on the trim. I use the 303 on the inside trim but if you want a shiny interior trim 303 isn't the right choice. It should help keep the fading away.
Old Mar 28, 2005 | 08:04 AM
thanks for the info
still a little confused on the b-pillar (now i know what to call that area at least)...
and, i also realized the sunroof isn't yellow (for some reason i had been thinking it was- my old car, it was the same as the body). but i guess it is tinted plexiglass? sorry for all the questions, but what do you guys use on that?
Old Apr 2, 2005 | 01:22 AM
markd's Avatar
Sorry, I didn't see that you'd posted more questions until just now. Sad how things get lost in the shuffle sometimes...
Anyway, the only thing you really need to clean from the b-pillars (and just a little FYI, the sides of the windshield are the A-pillars ) are fingerprints, so in a jiffy, you can just QD or wet-rag it, wiping off the prints, although that method will not prevent future fingerprints, unlike wax, if what Cam says is true. I'll have to investigate!
As far as the sunroof, right now I am using a foaming window cleaner. If you use something like that, make sure that when you do spray the window, you don't do it during any breeze. Otherwise, you'll get it all over the roof--I know this from experience Since it's a factory tint and not aftermarket, I don't think most any product you use will be harmful to it.
Finally, just as a little tidbit, when you're waxing your car, you might want to 'slide' your sunroof open slightly, so that when you detail the roof, you're much less likely to get wax on the rubber lining of the sunroof.
Good luck and have fun
Old Apr 4, 2005 | 07:25 AM
markd....you're right...i need to stop saying C*%$!@ite
Old Apr 4, 2005 | 03:05 PM
MDRX8's Avatar
Use
303 on b pillar and once your trim gets a little age or wax on it use
http://www.properautocare.com/fb-1k.html
iwannarun
Sep 6, 2015 01:37 PM
PTQLam
Sep 5, 2015 01:14 PM
Rupanrx
Sep 4, 2015 06:44 AM
wayloco
Sep 1, 2015 09:03 PM
