Sat radio
Old Mar 24, 2005 | 12:32 PM
bmcc49er's Avatar
Sat radio
I know, do a search but i can't make heads or tails so i am going to try to simplify it for anyone willing to answer. I want to put Sirius in my nonbose 04. I heard a simple plugin with a fm modulator gives crappy sound. i see the Sirius kits at Walmart and assume that is what they are. How in the hell do I install Sirius Sat radio in my car? What all exactly do i need? Any help? Wife says I can do it for Father's Day.
Old Mar 24, 2005 | 01:43 PM
Napboy's Avatar
Sho'Nuff
Originally Posted by djseto
Dont use FM modulation. Spend the $100 or so bucks to get the PIE Interface to add an Aux In to your head unit. Check out www.rx8garage.net . Get the Sirius Starbase. If you do an install similar to the XM Commander (do a search for XM Commander), you can fit it in the cigarette lighter/ash tray area.
i second this method... i did it and it sounds great.
you could also figure a way to upgrade to the latest version of the radio and have the dealer install sirius for you. i'm not sure if anyone has done it yet, but it's possible.
Old Mar 24, 2005 | 03:22 PM
StphNieuw's Avatar
Installing the SAT Radio isn't that hard. I got a mount from ProClip for my RX8 and I have the antenna inside the car and sof far so good. Just take your time to hide the wires and like the other people have mentionedit sounds best with a direct connection.
Old Mar 24, 2005 | 04:00 PM
bmcc49er's Avatar
Is that the PIE Maz/PC-alp? for 75.99 on that site ?
Old Mar 24, 2005 | 04:10 PM
bmcc49er's Avatar
So let me see if I am close to being on track. Buy this tuner kit on the link and instead of using the fm modulator that comes with it by the pie and connect this same kit to the HU using the pie? Correct or am I still a Sat dumbass?
http://www.crutchfield.com/S-ZMxg1zK...950&I=607SCFM1
Old Mar 24, 2005 | 04:20 PM
bmcc49er's Avatar
Do you have pics of the install with the antenna in the car?
Old Mar 24, 2005 | 04:56 PM
modena's Avatar
Modena
This might help you out:
Pie adapter in radio
XM Radio on Pro-Clip mount
Antenna on rear shelf
Attached Thumbnails Sat radio-rx-8_amp_wiring-1-large-.jpg   Sat radio-rx-8_xm_radios-05-large-.jpg   Sat radio-rx-8_xm_radios-08-large-.jpg
Old Mar 24, 2005 | 05:33 PM
bmcc49er's Avatar
Perfect, thanks Modena.
Old Apr 5, 2005 | 07:53 PM
sidekick's Avatar
Great job... want to come to ny and install XM in my car...
If buy XM at bestbuy they said they will install for free. Will they mess up the car. Also I have 04 GT (with bose and a single cd) do i need to buy anything else to to install the radio.
thanks
Old Apr 5, 2005 | 08:04 PM
kachud's Avatar
Mad Scientist
thanks
You need the PIE adapter
Old Apr 5, 2005 | 08:23 PM
modena's Avatar
Modena
thanks
Get all the parts and I will be over, maybe split the airfare?
Been a while sins I was in NY....
(Changed XM units in the mean time)
Same model but has red lighting now.
Old Apr 6, 2005 | 08:12 AM
lurch519's Avatar
www.evoperform.com
hey sidekick, do you have the factory nav? if so there is another option for installing sat(either xm or sirius)/nav/changer/video sources
Old Apr 6, 2005 | 09:44 PM
BoilerX8's Avatar
I just bought the Starmate for Sirius Sunday and have been using the FM modulator and have gotten great sound!!! I guess it depends where you are, but in Indianapolis, the FM mod works great and is the most cost efficient method. Now where to mount it, well that is another issue...
Old Apr 18, 2005 | 08:12 PM
bmcc49er's Avatar
Where did you mount it and by any chance did you have luck putting the antenna in the rear deck vs outside the car on the trunk? I think i am going to go with the FM modulator for now and if it doesn't work I can change it out. Pics would be great of your setup.
Old Apr 20, 2005 | 09:14 PM
shortcrakr's Avatar
is this method possible with the base radio or do i need the cd changer and it's controls?
Old Apr 20, 2005 | 10:51 PM
Tamas's Avatar
Registered Lunatic
Works just fine with the base radio - as long your firmware is at 9.55 or above. To check that, turn on the radio, press and hold down the "TEXT" button and press the preset "1" button. Your display will show your head unit's firmware version. If yours is under 9.55, get it upgraded at www.mazdaparts.com for $50.
The PIE provides an auxiliary signal source input to the head unit. That's all you need.
Old Apr 21, 2005 | 10:51 PM
shortcrakr's Avatar
thanks
Old Apr 21, 2005 | 10:57 PM
shortcrakr's Avatar
One more thing . sorry. There ae 2 items on mazdaparts.com
1) P.I.E maz/pc-alp for 76.50 and
2)Rca inputs for maz/pc alp
Do i need both or just the first one. Appreciate it.
Old Apr 22, 2005 | 01:15 AM
Tamas's Avatar
Registered Lunatic
Both.
Old Apr 22, 2005 | 05:22 PM
shortcrakr's Avatar
cool
Old Apr 23, 2005 | 05:14 PM
shortcrakr's Avatar
I talked to mazdaparts.com and they said the pieces are on backorder for about a month. Do you know of any other places to purchase them.
Old Apr 23, 2005 | 09:11 PM
Rx-Appreci-8's Avatar
It pretty hard to beat the P.I.E and its associated RCA adapter for maz/pc alp. Works great! Also if you want multiple inputs (sat radio, iPod, phone handsfree, etc.) consider a SoundGate AUX3 ($40 if you search the Internet) or something similar in front of the PIE RCA adapter.
Old Apr 23, 2005 | 10:13 PM
BoilerX8's Avatar
Bmcc,
The starmate will fit in the stock ashtray area, no problem. I had the antenna in the trunk but was having issues, so i put it on one of the child seat anchors in the back window area and have max satellite signal. I like the starmate, because it is extremely portable, as I use this at work, as well, since we can not use the internet to listen to the radio.
Old Apr 24, 2005 | 10:44 PM
bmcc49er's Avatar
Bmcc,
Silly question but how do you get the Starmate in the ashtray? I can slide out the little trash compartment but what about the other side with the cig lighter? I am thinging of taking my Sportster and putting it in my wife's Map comparment of her 6 and putting the Starmate in the ashtray as you suggested.
