Greddy kit owners! Has your heat wrap fell off?
Old Mar 18, 2005 | 05:35 AM
Broke_Apex_Seal's Avatar
Had my car on the lift last night doing an oil change and saw that the wrap had all fell off! Left a yellow type residue? I guesss I need to get something better? Any ideas?
-Ryan
p.s. the oil line wrap is fine because I used wire to tie it down with.
Old Mar 18, 2005 | 12:36 PM
loube's Avatar
I found a piece of my heat wrap that goes across from the turbo on the car, on the ground the other day. Not sure what i'm going to use in its place yet. :D
Old Mar 18, 2005 | 02:19 PM
Yeah same thing here I found a pc just laying on the ground.
Old Mar 18, 2005 | 03:37 PM
smrx8's Avatar
Next is the turbo :D
Old Mar 18, 2005 | 05:35 PM
http://www.thermotec.com/products/full/full.html
try these guys.
While your at it buy the tubing cover for the air conditioner line. Then you will have cold air.
Old Mar 18, 2005 | 06:54 PM
Booosted's Avatar
Rap ur exsisting Heat Wrap with some Mechanic ties, that will do the trick
Old Mar 21, 2005 | 01:14 AM
Silverarrow's Avatar
OldeSpeede, Inc.
yeah, same problem here, i was thining of going way out and cutting a portion of the floor out to have it jet hot coated and then welded back in, don't know if that would acheive the desired effect, not to mention having the flintstone mobile for a bit.
Old Mar 21, 2005 | 01:36 AM
Hou-TX-RX-8's Avatar
For people who are going to purchase in the future would it make sense to have the inside of the manifold and other high temp areas ceramic coated on the inside??
Old Mar 21, 2005 | 05:25 AM
that is the stuff it came with (thermo wrap).
Old Mar 21, 2005 | 07:07 AM
guy321's Avatar
Humpin legs and takin nam
Just wondering, did you guys tape the thermo wrap edges with aluminum tape?
Old Mar 21, 2005 | 10:16 PM
OldeSpeede, Inc.
I've always heard it wasn't a good idea to do that right before the cat. I.E. if you get headers coated not to coat the y-pipe, i may be wrong though.
HMSS013
Series I Do It Yourself Forum
Apr 9, 2023 09:13 AM
RicerX1
Jan 11, 2016 05:59 PM
Dolpho69
26
Jan 7, 2016 10:23 AM
cschoeps
Aug 6, 2015 12:44 PM
