Part weights
Old Mar 16, 2005 | 12:58 AM
Jarred's Avatar
Part weights
anyone have a list of parts and their weights in stock the 8? like seats, flywheel etc?
I've been searching the web with no luck. Sorry if this post is in the wrong section....
Old Mar 16, 2005 | 08:48 AM
mlx8's Avatar
There are a whole group of posts on flywheel weights (try seaching on "LWFW" for light weight flywheel.)
There are also several threads on brake rotor and rotor weights as well as wheel weights.
Old Mar 16, 2005 | 11:30 AM
brillo's Avatar
Go Texas Longhorns!
do a search for my posts, I've posted several things, battery, wheels, covers, etc..
Old Mar 16, 2005 | 01:13 PM
ScudRunner's Avatar
On time, on target
^^^You should consolidate!!!:D
Old Mar 16, 2005 | 01:54 PM
mikefrombarrie's Avatar
Fly wheel 21.5lbs
Battery 38.6lbs
Exhaust 38.7Lbs
Bridgestone tire 28 Lbs Each
Stock Rims 23Lbs Each
Old Mar 16, 2005 | 04:45 PM
army_rx8's Avatar
X-Sapper
^youza that's a fat battery we got:p
Old Mar 16, 2005 | 05:03 PM
Jarred's Avatar
I was just thinking the same, anyone here recommend a lighter battery ?
Old Mar 16, 2005 | 05:21 PM
Jarred's Avatar
what about hood, pullies? bumper?
Old Mar 16, 2005 | 07:38 PM
Pullies are about 4.4Lbs
Old Mar 17, 2005 | 05:04 PM
Jarred's Avatar
anyone here thats replaced their hood wiegh the stock hood ? I' plan on making a list and posting it up on a webpage....
Old Mar 17, 2005 | 05:24 PM
Fanman's Avatar
I believe the stock hood is around 11-12 lbs. It is aluminum, so changing it out for another material like Carbon Fiber will not save much weight.
Old Mar 17, 2005 | 10:57 PM
robertdot's Avatar
I already tried this. I can merge this thread with the other if anyone is interested in trying again...
Old Mar 20, 2005 | 01:06 AM
brillo's Avatar
Go Texas Longhorns!
https://www.rx8club.com/showthread.p...ghlight=weight
some of the above weights are incorrect. The wheels weigh in at ~22lb (see my garage for pics of the wheels being weighed, the tires are 26lb.
note: my battery is the smaller original one.
Old Mar 20, 2005 | 01:39 AM
Fanman's Avatar
Originally Posted by brillo
the tires are 26lb.
Tire Rack says the tire weighs 27 lbs. Must be the driving time wore away some rubber :D
What battery are you using, and how much (different) does it weigh ?
Old Mar 20, 2005 | 02:06 AM
Jarred's Avatar
I'm trying to combine as much of the stock weight data as possible, then search for lighter counterparts, so I can project how much weight reduction can affordably be done to the 8. I know there are visitors here who have replaced many parts, it's just a matter of getting the information from them, If merging threads means there's a chance of fewer people seeing it, then I'm against it!
Old Mar 20, 2005 | 04:41 PM
On the bridgestone web site, they say that our tires, 225/45/18 are 28lbs each
Old Mar 20, 2005 | 09:35 PM
robertdot's Avatar
Merging threads helps people find information easier.
iwannarun
Sep 6, 2015 01:37 PM
PTQLam
Sep 5, 2015 01:14 PM
Rupanrx
Sep 4, 2015 06:44 AM
wayloco
Sep 1, 2015 09:03 PM
