djmano
03-10-2005, 08:35 PM
hey guys i recently ordered a set of oem pads off rosenthal mazda's website. went down to my local mazda dealership and they quoted me $81 dollars to install the front pads (not with rotor resurfacing, thtas an extra 80 dollars). my question is, is that a reasonable price for install? is there any places in the socal area which would do the install for reasonably less? i am not mechanically inclined enough so i cannot do it myself. thanks.
i am leaning towards the dealership b/c that way with oem pads installed by a factory authorized dealership i am in the clear with any kind of warranty issue.
adrian-1
03-10-2005, 09:00 PM
If you change your mind about doing it yourself, here's the Do It Yourself (http://www.rx8club.com/showthread.php?t=38037&highlight=brake) by polak. It's one of the easier maintenance jobs.
I'm not sure if that rate is decent, sounds high to me for removing wheels, remove caliper and pads, goop up and replace.
Im_DANomite
03-10-2005, 09:03 PM
how much is the hourly shop rate at your dealership? i work at BMW and our hourly shop rate is $95. we charge 2 hours for both front brakes (which includes rotors, pads, and pad wear sensor) i'm gonna say that the mazda dealership isn't $95 an hour, maybe around $80. so for them to slap some pads on (which is half the work on a full brake job) they are gonna charge you an hour. so $81 sounds about right. honestly though, pad slapping takes no where near an hour.
TCHPET2
03-10-2005, 09:07 PM
Are you sure the ones you have now don't "squeak"? If so, you could probably get them replaced under TSB: http://www.finishlineperformance.com/rx8/docs/pdf/04-006-04-1369b.pdf
Although if your car doesn't qualify, I guess you will need to pay for it or do it youself.
Just a thought ;)
