dazygirl415
03-10-2005, 10:07 AM
Can someone tell me how many light bulbs I would need to order for the inside of the car if I replaced them with LED's? Mine is out of commission and I can't just go and count them. Thanks!!!
View Full Version : HELP!!! Inside Lights Question dazygirl415 03-10-2005, 10:07 AM Can someone tell me how many light bulbs I would need to order for the inside of the car if I replaced them with LED's? Mine is out of commission and I can't just go and count them. Thanks!!! XeRo 03-10-2005, 11:27 AM 4 and they are all 194... http://www.rx8club.com/showthread.php?t=25466...this will help with future bulb questions.. slllygrl10 03-10-2005, 12:22 PM Which lights? there are about 5 including the dome light. truemagellen 03-10-2005, 12:49 PM FYI changing interior bulbs to LED have one drawback...LEDs are either on or they are off so the lighting will not fade in and out when you unlock or lock as it does currently with incadescent bulbs I wanted to keep the Fading so I put in hyper white incadescent replacement bulbs that give the interior an eery glow...many on the forum have put in red, blue, and other colors (even black light :)) Another drawback to LEDs are how expensive they are...when you need to swap map lights 2 overhead 1 (specialty bulb even more expensive) in-door lights vanity mirror lights (optional :)) it adds up quickly...save the LEDs for the exterior I can even show you how to install LED blinkers with load equalizers to prvent the triple blink NVMYGT 03-10-2005, 03:49 PM I can even show you how to install LED blinkers with load equalizers to prvent the triple blink I'm definitely interested. dazygirl415 03-10-2005, 03:53 PM I just ordered some so when they come in, I'm taking you up on your offer Truemagellen. :D Rotary Rasp 03-10-2005, 03:58 PM FYI changing interior bulbs to LED have one drawback...LEDs are either on or they are off so the lighting will not fade in and out when you unlock or lock as it does currently with incadescent bulbs I wanted to keep the Fading so I put in hyper white incadescent replacement bulbs that give the interior an eery glow...many on the forum have put in red, blue, and other colors (even black light :)) Another drawback to LEDs are how expensive they are...when you need to swap map lights 2 overhead 1 (specialty bulb even more expensive) in-door lights vanity mirror lights (optional :)) it adds up quickly...save the LEDs for the exterior I can even show you how to install LED blinkers with load equalizers to prvent the triple blink My LEDs fade like stock. truemagellen 03-10-2005, 04:25 PM My LEDs fade like stock. they fade in slow motion? |
