Rev Boost -- 18.1lbs ??
Old Mar 7, 2005 | 12:26 PM
BigOLundh's Avatar
#1 Legend
Has anyone heard of these wheels before? If so, how is the quality?...
Make: Rev
Model: Boost
Size: 18" X 7.5"
Offset: 42mm
Finish: Silver or Gunmetal
Weight Claimed: 18.1lbs
Price: $500 for all 4
Silver:
Gunmetal:
Old Mar 7, 2005 | 12:58 PM
TxRx8's Avatar
Bipolar Member
At 18 lb's that's a good deal! Don't know about the 7.5 tho.
Old Mar 7, 2005 | 02:45 PM
Jabberwock's Avatar
it should be at least 18X8
Old Mar 7, 2005 | 03:33 PM
dmp's Avatar
dmp
RX8 and a Truk....
weird how ppl ask for help, then add on a '***-sounding' tag line like:
this might be a repost, but I don't care.
Old Mar 7, 2005 | 04:49 PM
Reactionary's Avatar
He is merely getting ready for the ********.
Old Mar 7, 2005 | 04:53 PM
TxRx8's Avatar
Bipolar Member
nice
Old Mar 7, 2005 | 05:26 PM
Yes, the ******** are not nice. But they exist. And he knows that.
Old Mar 7, 2005 | 06:00 PM
BigOLundh's Avatar
#1 Legend
thats right... I am tired of the repost police hunting me down, and being the first to announce that they have seen this before.
Speaking of the rims. 7.5 does seem somewhat short, but for that weight/price its very tempting nonetheless. Will the offset fit on our cars?
Old Mar 7, 2005 | 06:10 PM
pimpindarx8's Avatar
I was considering those same rims 19". I was told not to get them cause they arent that great but im not sure they seem ok to me.
Old Mar 7, 2005 | 11:21 PM
BigOLundh's Avatar
#1 Legend
i did not even think they came in 19s. Most of there rims are only 17s and now they have a few 18s. I did see one model that was 19/20s, but i wasnt a huge fan of the 25 spoke look on an rx8.
Old Mar 8, 2005 | 07:15 AM
They have 2 rims in 19 you can call them. They also have those rims you want in black with a lip
Old Mar 8, 2005 | 07:42 AM
Imp's Avatar
Imp
What's next?
And the reasoning for that is?
Stock tires are 225/45-18 which would be fine on a 7.0" through 8.5" wide wheel.
(See wheel width: http://www.tirerack.com/tires/Spec.j...=Potenza+RE040 )
There's no special reason that they 'have to' be 8" or higher.
The thing I would question is the offset on the wheels since stock is ~50... if you're going to a 'thinner' wheel, would not the offset need to INCREASE to center the wheel over the hub? A 42 offset pushes the wheel out towards the fender of the car, putting more stress on the hubs/bearings.
What I don't know is what's the acceptable offset range for the 8. For example, Subarus. Offset is also around 52mm. People were getting 42 offset wheels and blowing out their bearings in about 8-10K miles since there was too much load/weight to the outside of the designed specification of 52mm. Depending on wheel width, offset must be taken into consideration on modern cars where tolerances are much tighter. If you necrease wheel width, you should be decreasing the offset, and vice versa. (Again... Stock WRX wheel is 16 x 6.5. Going from a 16 x 6.5 to 17 x 7.5, the offset would go from 52 to 48 to keep the wheel centered. Going to a thinner wheel, you'd go from 52 up to around 55.)
Just something to keep in mind.
I know there'll be people that will chime in saying "I own these wheels and they're fine" or some such... so I really don't know how strong the 8 hubs/bearings are. Just asking here and throwing out another data point.
--kC
Old Mar 10, 2005 | 07:24 PM
BigOLundh's Avatar
#1 Legend
Thanks for the info IMP, that is good advice...
I just noticed that the wheels in the pics are 4 lugs... I hope they make them in 5 as well.
-HS
Old Apr 10, 2005 | 04:11 PM
BigOLundh's Avatar
#1 Legend
I hate to bump my own thread, but...
IMP or anyone, can you explain to me what the offset on a wheel refers to?
Old Apr 11, 2005 | 10:36 AM
Imp's Avatar
Imp
What's next?
I'll go one better:
http://www.tirerack.com/wheels/tech/offset.jsp
--kC
Old Apr 11, 2005 | 12:24 PM
BigOLundh's Avatar
#1 Legend
Thanks for the link man...
Maybe im missing something here. If the offset on the stock is 50, and this wheel is 42. Wouldn't that bring the wheel further in, and away from the fender. This seems to be balanced because of the narrower wheel (7.5" Depth).
Shankapotamus3
Mar 14, 2021 03:53 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
Jb4ker96
Sep 27, 2015 10:06 PM
