Problems with spring install
Old Mar 5, 2005 | 08:30 PM
Gray Ghost's Avatar
HPDE Fan
I got my Tein H Tech springs installed last week and when I got the car back it sat higher than with stock springs. I searched other threads and saw the preload information. I loosened the two upper control arm bolts on each side and it let the front suspension settle close to what the manufacturer states. The problem is that I can't figure out the rear springs. The rear is now 3/16" higher than stock and I don't know what could have been preloaded or what to look at to fix this problem. Any help that you can provide would be greatly appreciated.
Old Mar 5, 2005 | 10:34 PM
greene76's Avatar
When I first installed my mazdaspeed springs, it sat higher than stock, but after a few days it slowly settled to the correct height. How long has it been?
Old Mar 6, 2005 | 07:07 AM
Gray Ghost's Avatar
HPDE Fan
I had them installed on Thursday but I haven't really driven much since the install.
Old Mar 6, 2005 | 05:23 PM
stownz's Avatar
Keep us posted after they settle a bit more. I just purchased the H-tech springs and I'm planning to install them in a week. I'll let you know how mine goes.
Old Mar 6, 2005 | 10:33 PM
irish8's Avatar
Get in ma belly!!
Grey ghost.....they should settle a little. I would urge you call Tein and discuss this issue with their tech support. The car should have settled by now!!
BTW...the H-tech's only lower the front 1.02" and the rear .31". How did you measure prior to the install?
http://www.tein.com/ti/m58.html
- Irish
Old Mar 7, 2005 | 07:25 AM
Gray Ghost's Avatar
HPDE Fan
After driving it yesterday the rear is starting to settle so things are looking up. The front has dropped between 5/8 and 11/16 and the rear has dropped 1/16 from stock. Hopefully as I get a few more miles on it the springs will continue to settle. I might loosen the front again to see if I get any additional drop.
xAgyex
Jun 3, 2026 03:47 PM
WingleBeast
22
May 23, 2016 09:22 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
steve11711
Aug 22, 2015 11:11 AM
Belalnabi
Jul 17, 2015 07:48 PM
