Build-out of 2005 RX8 for SCCA T3 Racing...
Old Feb 24, 2005 | 08:21 PM
Rob Lay's Avatar
Hello, I'm new here, but will come around more often as we build out the RX8 and start racing it. I've been racing SRX7's for 3+ years and now I'm looking forward to a national class with the RX8.
Bought from the dealer with 4 miles 2/9/05...
Back from paint 2/20/05 to get a black racing stripe...
Took to the dyno today for a base run...
How can Mazda get away with publishing 238 HP numbers!?! Anyone know the full story behind that? I know there was a law suit, but didn't that just make them lower to 238 from 245?
Even a 20% loss factor should pull 190 at the rear wheels.
700 Miles
100% Stock
Dynojet HP: 164.4
Torque: 128.1
I would feel something is wrong with my individual car, but the exact same dyno had a new 2004 on it that went 165.6 HP and 132.4 Torque.
Notice the unlinear curves? Is that some variable timing or what? Both my RX8 and the 2004 had the same curve.
Anyone share what they've seen other stock RX8's go? How much to expect from air filter and exhaust?
Also, I heard 5th gear is 1:1, so how much did we loose from this run being in 4th? 3rd gear was only a couple HP from 4th.
Thank you,
rob
Old Feb 24, 2005 | 09:43 PM
clyde's Avatar
www.TeamWTF.org
I really hate to tell people to search, but your dyno questions have all been thoroughly discussed many, many times before. In a nutshell, there is a question about whether the ECU flips out when the cars are run on dynos preventing the operator from getting accurate readings. The non-linear curves are pretty common.
Look forward to watching your car's development, and welcome!
Old Feb 24, 2005 | 10:02 PM
RevTo9K's Avatar
1.3L is enough 4 anybody
There's some speculation that the ECU cuts power when it detects the rear wheels moving, and the front wheels standing still.
Old Feb 25, 2005 | 07:11 AM
crossbow's Avatar
Also remember that most cars dyno less when new...and more when older. Didn't the FD's use to have some sort of magical "switch" that flipped over around 20k miles?
I know the mazda 6 gains around 10-15 extra whp by 30k miles (vs a sub 10k dyno).
Old Feb 25, 2005 | 10:53 AM
alnielsen's Avatar
Aren't you in T2 when running National events and T3 is Regional only? Good graphics design. I will be looking forward to your reports on your progress.
I use to run 82 & 85 RX7's in ITS.
Old Feb 25, 2005 | 01:12 PM
Rob Lay's Avatar
Yes, get beat by M3's, F Bodies, and Neons for at least another year.
Old Feb 25, 2005 | 01:27 PM
RX8-TX's Avatar
Senior Geek
700 Miles
100% Stock
Dynojet HP: 164.4
Torque: 128.1
Thank you,
rob
Read up some info here: http://www.myrotarycar.com/mazda-rx8...Horsepower.asp
And some dynos here: http://www.myrotarycar.com/mazda-rx8_2004_Dynos.asp
Old Feb 25, 2005 | 01:32 PM
dmp's Avatar
dmp
RX8 and a Truk....
Did you run with your dsc/tcs 'totally' disabled? (More than the dsc light off?)
Is that corrected or measured hp?
Old Feb 25, 2005 | 02:34 PM
Rob Lay's Avatar
This is just a base model.
Dyno chart says STD.
Old Feb 25, 2005 | 02:42 PM
Rob Lay's Avatar
Originally Posted by RX8-TX
Thank you! Great information.
Has anyone run back to back comparing 4th gear to 5th gear? Someone told me 1:1 5th Gear would improve numbers 10-15%. I find that hard to believe, my run was in 4th.
Old Feb 25, 2005 | 03:03 PM
TrackAddict's Avatar
I miss my 'Bu
I really like how those stripes turned out. Looks fast!
Old Feb 25, 2005 | 03:17 PM
Rob Lay's Avatar
Thank you, I didn't want to go crazy, but didn't want just base paint either. SRX7's had two racing stripes, but on RX8 the hood and roof contour don't lend itself to that. So just an offhand quick decision to meet the stripes within the hood contour.
Old Feb 25, 2005 | 03:18 PM
dmp's Avatar
dmp
RX8 and a Truk....
I guess I don't know what STD means in relation to if a 'correction value' was mulitiplied in or not.
Old Feb 25, 2005 | 03:19 PM
dmp's Avatar
dmp
RX8 and a Truk....
I'm going to do a back-to-back 4th and 5th gear run tomorrow
Old Mar 1, 2005 | 03:33 PM
Rob Lay's Avatar
How did it go?
Old Mar 1, 2005 | 03:39 PM
dmp's Avatar
dmp
RX8 and a Truk....
How did it go?
I'm a liar. I did only 5th gear dynos. However, I did a 1-6th gear run...no real difference..
186hp/144lbs-ft
Old Mar 1, 2005 | 04:39 PM
Rob Lay's Avatar
186hp/144lbs-ft
Well, we're still unable to prove the 4th/5th gear theory.
Does your car have any mods?
Thanks.
Old May 9, 2005 | 09:58 AM
Rob Lay's Avatar
The safety stuff has been completed, it has a log book, and I participated in my first national day.
All the racing stuff needs to be done still. Only thing it had was front pads and Hoosiers. I couldn't even hear the car, but could hear the race cars on the other side of the track.
Hopefully have more of the racing stuff done by the R/N at TWS in 3 weeks.
Old May 9, 2005 | 10:04 AM
dmp's Avatar
dmp
RX8 and a Truk....
Thanks.
sorry I missed your question - No...my car was, and is stock.
Love the cage, etc, on yours! looks awesome!
Old May 9, 2005 | 10:06 AM
NAVILESRX8's Avatar
FWD Hater
that is awesome. Hey do you still have the rear seat bottoms? If you do can I get them?
Old May 9, 2005 | 11:16 AM
Rob Lay's Avatar
Thanks all.
The seats will have to go back in. Didn’t have time this weekend.
ROCKSTAR RX8
Canada Forum
May 7, 2007 07:34 PM
ROCKSTAR RX8
RX-8 Racing
Apr 28, 2007 09:25 AM
