djseto
02-23-2005, 02:12 PM
As I understand it, we dont have 250HP because of emissions.....so why cant we just find someone with a Japanese Flash and have them send it to us and find someone to flash it here? Other than the software, is there anything on our US cars that has been changed to detune the engine to our 238HP?
epitrochoid
02-23-2005, 03:50 PM
i dont think the japanese flash will even load onto a non-JDM ecu. but even then, the code is well encrypted (anyone put it on a logic analyzer?) and loading it onto the ecu requires the mazda tool...you've have to know some brass to get that done.
Buy an aftermarket PCM or piggyback.
You can not update PCMs programs like a PC program, it is just not that simple.
RX8_Ownz
02-23-2005, 06:10 PM
What about just swapping to JDM ECU?
Well then you run into the problems where the Japanese versions of the rx8 have a different setup, some emissions equipment not present, etc., where we US models still have all that stuff. Without the ECU to control them they probably wont do anything.
Now if you completely removed emissions and swapped harnesses I don't see why that wont work, but you'd have to do a fair amount of swapping for things.
Mazmart
02-23-2005, 06:23 PM
Are the Japanese cars actually getting higher numbers? I don't believe I've seen anything to document that.
No idea, I just got my rx8 yesterday :p:
zoom44
02-25-2005, 03:22 PM
Racing Beat has the capability now to "flash" the pcm with customized maps
DARKMAZ8
02-25-2005, 03:34 PM
I believe that all u would have to do to run the j-spec ecu is block off the egr, and plug the ecu in......u might want to disable the j-spec speed governer tho :) .....
are there any japan 8 dynos?
rx8wannahave
02-25-2005, 03:55 PM
Who, what...when...who, what....what when...who?
RB flashing the ECU (why do you call it pcm?) of the RX8? Any more news about that?
CERAMICSEAL
02-26-2005, 12:53 PM
Powertrain Control Module. It's the terminology used by most manufacturers today.
truemagellen
02-26-2005, 05:32 PM
dang I thought this was going to be pics of Japanese woman :p
as everyone says it wont work...but even if you swapped everything you'd have problems...CEL CEL CEL and more CELs...it wouldn't be worth it
just work at Racing Beat :)
