NEW K&N INTAKE! Typhoon Replacement?
Old Feb 22, 2005 | 01:49 PM
pret's Avatar
AbsolutelyNothingHappenin
New for our beloved 8's.
What do you guys think of this intake?
Old Feb 22, 2005 | 01:52 PM
the filter looks cool...
Nemesis8's Avatar
Bigus Rotus
Where did you see that?
Old Feb 22, 2005 | 02:00 PM
Cam's Avatar
Cam
this space for rent
Looks like a SEMA booth display possibly.
Anyone check the K & N website yet?
Old Feb 22, 2005 | 02:04 PM
TxRx8's Avatar
Bipolar Member
I wonder if that filter would fit on my typhoon??? If so I want one. Now.
Old Feb 22, 2005 | 02:05 PM
jenkins-crew's Avatar
Where is that and how much?
Old Feb 22, 2005 | 02:07 PM
rotarygod's Avatar
Apparently K&N has heard the criticism about how their filter blocks all the incoming cold air. too bad the filter element area is extremely small. It probably lost airflow.
Old Feb 22, 2005 | 02:09 PM
K&N doesn't have that one on there website:
http://www.knfilterchargers.com/search/appsearch.aspx
Old Feb 22, 2005 | 02:14 PM
pret's Avatar
man you guys are fast!
ok, this was a SNEAK PEEK of an upcoming intake for our 8's. (provided to me by a vendor). as soon as i know pricing and availability by k&n i can redirect.
btw, i have no affiliation with either k&n or the vendor.
so, over the typhoon, will this increase the air flow rotarygod?
Old Feb 22, 2005 | 02:15 PM
I doubt it, but why would they be changing it?
Old Feb 22, 2005 | 02:36 PM
rotarygod's Avatar
The problem they had wasn't lack of airflow through the filter. Their filter was huge and could easily flow enough. The issue was that it couldn't get cold air. Now, this new filter has a much smaller flow area but it can take in cold air from the stock inlet opening. It's kind of like they are willing to make one sacrifice for another. Why not just do the whole thing properly like Racing Beat? FWIW: Racing Beat will use a K&N filter element in theirs. Their kit only gets air from the outside rather than using a shield. It has plenty of area inside the intake box to get it to the filter and the filter is large enough to not be a restriction. K&N isn't doing their homework for this car very well.
Old Feb 22, 2005 | 03:23 PM
pret's Avatar
update
this just in from vendor....
More HP. Filter is NOT sold seperately. Available in LATE April. Price
will be the same as OLD typhoon kit.
will keep u posted!
Old Feb 22, 2005 | 04:31 PM
TxRx8's Avatar
Bipolar Member
Filter not sold seperatly! That Sux!!!!! Screw K&N, they should at least compensate for the **** they threw at us the first time around.
Old Feb 22, 2005 | 06:48 PM
that's what happens when a manufacture just rushes in.....i hate it when they do that!
Old Feb 22, 2005 | 06:51 PM
there is a filter a little better at intense performance anyway....
http://www.intenseperformance.com/pr...e_filters.html
it gets air from the front and sides
Outlaws eXtreme's Avatar
2010 Prius - Miss the 8
I can't wait to see how many HPs this one makes your RX-8 Lose... I say -10HP
Old Feb 22, 2005 | 07:36 PM
crossbow's Avatar
btw just a note (I love the S&B and intense performance filters), the S&B filters tend to exaggerate the whistle sound from the TB's...so if that really annoys you, they may not be the filter for you.
It might not whistle on the 8 at all...but damn does the mazda 6 TB plate hit just the right frequency at 3k rpm..
Old Feb 22, 2005 | 10:43 PM
David_M's Avatar
Although it's difficult to determine exact scale from a photo that's a pretty big filter housing, about 7 or 8 inches in diameter judging from its relative size compared to the cone filter below it. That would put the opening at 6 or so inches. Also the tube appears to be bigger, both slightly longer and larger in diameter than the previous K&N. I would like to see what's inside of the filter housing. If there is a venturi instead of a flat plate with a hole in the center flow should easily exceed the old K&N. I figure that if you unrolled the inverted cone it would be about 33% larger than the stock element. While that is smaller than the previous K&N filter it is better positioned.
K&N screwed up the first time around but that's no reason to assume that this filter will be equally flawed. This design seems better thought out than the previous incarnation, I hope they have used the additional development time to good effect.
Old Feb 23, 2005 | 07:57 AM
therm8's Avatar
Bummed, but bring on OU!
From everything I've read, resonance in the intake and exhaust is very important to where and how much power is made in the Renesis. By removing the stock air box, you're removing the tuning chamber for that resonance, and thereby disrupting airflow to the engine. I noticed that Racing Beat retained an airbox in their prototype design. Just a thought.
Old Feb 23, 2005 | 08:44 AM
I just replaced the OEM filter with the Intense cone filter, the intake alreay has a great design....
Old Feb 24, 2005 | 10:37 AM
Speed Racer's Avatar
Certified track junky!!!
If K&N is working on a new intake design then it kind of shows that they have been listening to their customers and are trying to remedy the situation. If you look at this other photo of the prototype you can see that they added a velocity stack and a mesh screen to help stabilize the airflow.
So I say hold off on the flame fest. Well at least until the product is released and a few people have actually had a chance to try it.
Old Feb 24, 2005 | 12:18 PM
rotarygod's Avatar
If they are coming out with a proper design then that is fine. I'm still going to flame them for releasing an inferior design, making money off of it, and then not expecting the people that already have them to just buy new ones rather than offering them an upgrade option. Even after all this is taken care of, it still doesn't mean that their intake will really be of any performance benefit. Improving an area that doesn't need much help in the first place isn't a very effective way of getting good gains. They might get something out of it but don't expect any miracles.
Old Feb 24, 2005 | 08:09 PM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
Hahaha thats funny - why areyou ******* (thats meant w/love) stillwasting your cash on this type of ****? Get w/the turbo process people. Why delay the inevtiable for crap products like these which make your car sound like itjust had a bucket of KFC? The days of makingthe Rx8 SOUND like its fast have ended. Stop living in fantasy land people.
Old Feb 25, 2005 | 09:03 AM
All I'm asking is that people reserve judgement until someone has actually tried a product. Your attitude is very hostile towards vendors and in return it makes them very hesitant to make new products for our cars. I've spoken to several vendors about making performance parts for our cars (harness bars, 4-point roll bars, blade type anti-sway bars, wide throttle pedals, etc...) and in each case they decided not to pursue it because of the attitude on this forum. The general perception that they got after skimming through the forum is that RX-8 owners are a bunch of whiny posers who are only interested in trendy items versus functional performance items. So they don't see any reason to invest the time and/or money into developing parts for our car.
Old Feb 25, 2005 | 09:09 AM
army_rx8's Avatar
X-Sapper
^^wow first i heard this...wasnt' aware i was a whiny poser...guess i should start to act like one then:p LOL that is too funny. they won't make a product b/c of some peopel on the net whining....dn't they know that Al Gore only made the net for people to complain on forums....oh and **** hehehe...and most importantly fo rpeople to complain about ****:p LOL
