trophymaker
02-20-2005, 10:12 PM
Does anyone have an image of an RX-8 Powertrain cutaway or schematic that shows the engine and transaxle orientation? I trying to picture which way everything faces. Thanks.
View Full Version : RX-8 Powertrain trophymaker 02-20-2005, 10:12 PM Does anyone have an image of an RX-8 Powertrain cutaway or schematic that shows the engine and transaxle orientation? I trying to picture which way everything faces. Thanks. robertdot 02-20-2005, 10:21 PM transaxle? it's rear wheel drive... robertdot 02-20-2005, 10:29 PM Dunno if it helps, but here is a side view of the engine: http://www2.ocn.ne.jp/~otori/Images/kyozai/Rx8_01.jpg The fan is in the front. You can see where the tranny hooks up, which attaches to a drive shaft, which attaches to the axle in the rear, which attaches to the rear wheels. I know that takes some abstract thinking and isn't exactly what you asked for, but it's the best I can do in 5 minutes. ;) SantozRx8 02-20-2005, 10:31 PM ^ yeah what he said trophymaker 02-21-2005, 12:24 AM Yes that helps... I guess I need to see the eccentric shaft and how it is attached to the engine. Is it just a short shaft that attaches to the transmission? robertdot 02-21-2005, 03:16 AM The e-shaft runs roughly parallel to the drive shaft, just like a crank shaft would in a front mount RWD piston engine. Go to http://www.rotaryengineillustrated.com/ for more info about engine internals. |
