285/35/18
Old Feb 17, 2005 | 01:25 PM
cretinx's Avatar
In the rear . . .
Tires - 285/35/18
Wheels - 18" x 9.5", +45 mm offset
Connor at TireRack doesn't know whether these will fit - I'd like to try but as soon as I drive with them I can't send them back.
Anybody actually measured? Have opinions?
(and no comments on how staggered is bad, or these are too big - I owned an RX-7 with a single turbo and 265s out back - car melted them through 4th gear - I've already ordered the GReddy kit and plan to modify it extensively, so I need some grip in the back).
Old Feb 17, 2005 | 02:05 PM
epitrochoid's Avatar
Riot Controller
i think mazdatrix runs this size...but with a +45 wheel you're pushing it.
Old Feb 17, 2005 | 02:13 PM
PUR NRG's Avatar
"Pushing" in what sense?
________
ARIZONA MARIJUANA DISPENSARIES
Old Feb 17, 2005 | 03:57 PM
Fanman's Avatar
I have 265/30/19 on 35 mm offset (I have the RB springs though). At 275 they said it would rub.
Old Feb 17, 2005 | 07:17 PM
Riot Controller
nm, i thought he meant on all 4 corners. 285 on a 9.5 +45 should be ok in the back
fanman, you risk rubbing on the outside. with a +45 it's the inside he should be concerned about.
Old Feb 18, 2005 | 09:06 AM
cretinx's Avatar
I have no concern about rubbing the outside - the stock diameter is slightly larger than the diameter I plan on running - so it should just stick out past the fender if its going to stick out in that direction.
are you saying a +35 would be a better offset then?
Old Feb 18, 2005 | 09:35 AM
Riot Controller
no, stick with the +45...there's more room on the inside then the outside. you want to keep as close to OEM offset to maintain optimal suspension geometery.
Old Feb 18, 2005 | 01:20 PM
cretinx's Avatar
SWEET
lemme get on the horn with connor now.
4kruzn
Apr 8, 2012 08:27 AM
-RX8-
30
Jan 14, 2010 07:44 AM
RickA
Oct 15, 2009 12:48 AM
05MazdaRx8
Jan 11, 2008 10:32 PM
cretinx
Feb 11, 2005 11:16 AM
