please recommend a site to get (nice) but cheap and light wheels for autocrossing
Old Feb 13, 2005 | 11:37 PM
gxsilver's Avatar
can you please suggest some wheels and or sites to get cheap ( yet light and somewhat pretty) wheel for autoxing, and autoxing rubber
i'd like to have 18x9
thanks
Old Feb 14, 2005 | 10:19 AM
Dark8's Avatar
Ride Naked!
18x9 will throw you out of B Stock. If you are not planning on running stock, have you looked into 17" wheels? Cheaper, lighter, and more tire sizes available.
Old Feb 14, 2005 | 11:13 AM
crossbow's Avatar
Doesn't Kosei make a 17x8 now in a decent offset? Not only would you get the benefits of reduced weight, but all the benefits from reduced wheel diameter to boot. You could even run a similar or smaller profile tire (then stock) and give yourself more aggressive gearing.
Old Feb 14, 2005 | 11:37 AM
gxsilver's Avatar
i could look into 17, but I do want a wider tire.....i'm thinking about getting out of b stock anyway, i want to change the sway bars and springs as well as tires
any good suggestions on 17's ??
Old Feb 14, 2005 | 11:48 AM
Dark8's Avatar
Ride Naked!
This year to run STU I'm using Kosei K1 TS 17x8 with Kumho MX 255/40x17 which saves about 7.5 pounds per corner compared to the OEM wheel and tire. Cost me $1500 mounted and ballanced through TireRack.
Edit: Forgot to say to call TireRack because they will not show undersized wheels on their website. Call Conner and he will hook you up.
Old Feb 14, 2005 | 11:58 AM
gxsilver's Avatar
sweet, those are actually the tires I wanted......so, Kosei K1 TS 17x8, 114.3mm right ? and what backspace ??
thanks
Old Feb 14, 2005 | 12:00 PM
RA-Eight's Avatar
Scuderia
Inexpensive lightweight wheels are very rare. What price range are you thinking?
Try Velox wheels, I'm not sure if they have them in the correct offset but the brand is fairly inexpensive, and they carry lightweight wheels. I believe their site is www.veloxperformance.com
If money isn't an issue, I want Work wheels, www.worksuperwheels.com . I haven't seen any 8s with them.
Old Feb 14, 2005 | 12:03 PM
Dark8's Avatar
Ride Naked!
45mm offset: http://www.koseijp.co.jp/engfl/n_p5_k1.htm
Audio Concepts ATL
Sep 26, 2021 01:59 PM
WingleBeast
22
May 23, 2016 09:22 PM
mariohardleft
Feb 6, 2016 12:59 PM
Mr.BigSpoon
Aug 9, 2015 01:15 PM
