VFAD (Variable Fresh Air Duct) - Possible place to mod?
Old Feb 12, 2005 | 12:52 AM
Imidazole's Avatar
I heard that our 6-speed 8's have this. All I know is it allows more air at higher rpms. Could it be a good performance mod to enable this at lower rpms? Where is this? Does anyone have any details on this? Does this explain the sudden kick in the last 2k-3k rpms?
Old Feb 12, 2005 | 01:39 AM
robertdot's Avatar
Read RotaryGod's Post in this post and you'll see that the VFAD is tuned specifically for our intake system. If you want to tune the VFAD differently, you need to change the entire intake system to get good gains.
Old Feb 13, 2005 | 05:14 PM
olddragger's Avatar
Guys,
That is what Racing Beat is doing with their new airbox (when it comes out). The major change from stock is enlarging that intake area. Ive done a lot of work on my stock system and in my opion it has turned out better than any aftermarket one. Do a search on custom airboxs.
olddragger
Old Feb 14, 2005 | 12:05 AM
rotarygod's Avatar
By just opening the VFAD duct full time, you aren't gaining any low end. I drove brillo's car around this way for a while and it feels a little slower. Removing it entirely and redoing this with a new one could give more power. Just opening the duct earlier won't do it though.
Old Feb 14, 2005 | 01:04 AM
robertdot's Avatar
Originally Posted by olddragger
Guys,
olddragger
I saw their box. I couldn't remember if it had a replacement tube from the intake manifold or if it was just the box replacement. And, I wasn't sure if the fact that they didn't modify the intake manifold would, in the end, have changed that much on the tuning (i.e. not the entire pipe is bigger, just the first part of it) or the HP (it apparently only adds about +3, so...).
Last I heard, RB wasn't replacing or removing the VFAD... they replaced the airbox (and apparently the tube to the manifold). If they finally decided to, I stand corrected.
Old Feb 14, 2005 | 09:46 AM
rx8wannahave's Avatar
Follower of CHRIST!!!!!!!
Ditto, is RB doing this? That would be great...you got to give it to RB, they are the rotary experts out in the rotary world. I hope to be a customer becaue I like how they do things over there, cept for the price on some stuff.
If they modified the airbox/VFAD system and gained some significant HP per $, I would be at their door the next day...LOL
Old Feb 16, 2005 | 06:12 AM
Mr M's Avatar
Evolution of REvolution
You can have the VFAD permanently open by disconnecting the VFAD solenoid connector. The VFAD solenoid is the one attached to the aircleaner box.
(The solenoid provides vacuum to the valve at low rpm, to keep it closed. When the solenoid comes on atmospheric pressure is fed to the valve, allowing it to open)
Old Feb 16, 2005 | 10:10 AM
MyRxBad's Avatar
Fb's rock!
The intake is the perfect length and is engineered to take advantage of the HemHoltz (sp?) effect of supercharging. Do a search on Hemholtz here or on the net.
Old Feb 18, 2005 | 08:27 AM
Charles R. Hill's Avatar
Owner of BHR
Helmholtz resonance.
CRH
Old Feb 18, 2005 | 10:37 AM
MyRxBad's Avatar
Fb's rock!
Thumbs up
CRH
Thx for the corretion.
Old Feb 18, 2005 | 12:31 PM
Owner of BHR
correction. LOL.
CRH
gwailo
May 14, 2024 06:57 AM
RXFEVER
Sep 11, 2016 02:51 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
