Changing center display color
Old Feb 11, 2005 | 05:47 PM
N8theGr8's Avatar
Disturbed User
Is there any way to change the color of the display on the center console? I have some ideas on an interior project, but I'm not sure if that can be done.
Old Feb 11, 2005 | 06:42 PM
robertdot's Avatar
No luck so far, though I did suggest colored gels (or saranwrap if you are hard on cash).
Old Feb 12, 2005 | 08:53 PM
mazradiodoc's Avatar
I have looked at the display, I don't think this will happen.
There are about twenty little red LED's soldered to the board that would need to be replaced w/color of your choice and a red plastic sheet behind glass that would need to be replaced w/color of your choice.
Let us know if this is ever accomplished.
Old Feb 13, 2005 | 05:51 AM
truemagellen's Avatar
Attracts tree branches
I actually wouldn't mind bright white on a black background...a silvery color on black would be even better
cool
Old Feb 13, 2005 | 06:51 AM
yushinrt's Avatar
yea i want to change the door panel and the ingntion plastic with white and get a bright white led and the center display can be blue but i think if you do it your self to much time and if you get some one to do it to much cash lol good luck any way tell as if you accomplished it !!!!
Old Feb 13, 2005 | 11:24 AM
David Wiggins's Avatar
I swapped out the LEDs (stock is red) in the door panels that shine down on the switches. Switches are still backlit in red, but the front light is now blue. I've got blue LEDs on order for the ignition switch and ashtray lights. I removed the red filters from those lights long ago and tried some blue gel, but it looks like ***.
swapping out the LEDs that backlight the stereo/center console controls looks like a LOT of trouble. IIRC, they're all surface mount.
If you swapped blue LEDs in for your overhead and map lights, then did the doors, ashtray, and ignition key light, you could at least replicate the look of the gauge pod over the entire car. red backlight, blue front light.
Old Feb 13, 2005 | 12:43 PM
yushinrt's Avatar
show us pic plz i want to see lol
Old Feb 13, 2005 | 01:43 PM
yes seriously get those pics (in the dark and in light) up...nice work David
as for the display...I say someone pick one up used from Mazmart...have access to a de-soldering heat gun and go to town...just try it can't hurt
Old Feb 13, 2005 | 05:26 PM
It WILL hurt :D
Old Feb 13, 2005 | 05:57 PM
Originally Posted by mazradiodoc
It WILL hurt :D
:D I think you are right...sometimes I'm overly optimistic :p
Old Feb 14, 2005 | 07:38 PM
i'll post pics after i get my blue LEDs for the ashtray and ignition. hopefully they'll be the right size. I kinda guessed based on measurements, not on "this is a replacement for lamp size X"
we'll see.
Old Feb 14, 2005 | 08:07 PM
scottmhr1's Avatar
Don't use a heat gun on the led's, will burn them bad. Best option is a forked end soldering iron that matches the width of the led's. If you have that not very complicated at all. I work for Pioneer so know a bit about the subject
Old Feb 14, 2005 | 09:46 PM
yushinrt's Avatar
cool you work for pioneer very cool
Old Feb 18, 2005 | 07:50 AM
yushinrt's Avatar
any new news ??
sccarally
Gulf RX-8 Forum
Sep 8, 2015 10:34 PM
himynameisDD
Aug 17, 2015 12:40 AM
Supernaut6
Aug 11, 2015 07:28 PM
Jazzmeson
Jul 31, 2015 01:47 AM
Bamaham
Jul 23, 2015 08:08 AM
