Anyone else have new spark plugs installed.....
Old Feb 10, 2005 | 09:56 PM
ALWAZL8's Avatar
Who's Al? It means ALWAYS
Question Anyone else have new spark plugs installed.....
and notice a weird smell afterwards? It doesn't smell like gasoline, but it doesn't smell like oil either. I'm not sure if I should worry..... any ideas?
Thanks for any info.
Old Feb 11, 2005 | 06:01 AM
Go48's Avatar
Did you have anything else done at the same time? If so, what?
Verify that the plug wires are securely attached at both ends. Also check the battery cables as they may have disconnected the negative cable during testing and didn't reinstall it tightly enough. I suppose that the wires/cable could be loose and arcing giving off an electrical smell. If the smell persists, you should take it back in for a check.
Old Feb 11, 2005 | 09:06 AM
ALWAZL8's Avatar
They updated the PCM, but I also know that they had to recharge my battery for some reason. I had to reset everything the radio & clock when I picked it up yesterday evening. I called the service manager and he said the smell may just be from the flooding. Hmmmmm......
I'll definitely check the cables though. Thanks!
Old Feb 11, 2005 | 09:51 AM
Go48's Avatar
My car does have a definite unique odor that lingers with me for hours after being in the car for awhile, but I think that is normal for this particular car.
Not sure why they would have to charge the battery, unless they are powering their WDS from the battery, but they obviously disconnected a cable at some point. What you describe is what happens when you lose power from the battery.
I would suggest that you monitor the odor to see if it eventually goes away. If it doesn't clear up in a few days, take it back to the dealer. Good luck!
Old Feb 11, 2005 | 10:10 PM
ALWAZL8's Avatar
Thanks, Go48!
Old Feb 12, 2005 | 05:46 AM
Go48's Avatar
Thanks, Go48!
Sure. Let us know if you figure this out.
Old Feb 13, 2005 | 09:08 PM
miniviper's Avatar
I had that same smell as well for about 3 days after they updated my pcm, for a drop in my mileage. But yes if it does linger longer then 2 weeks or so i wuold have it checked out... But that was my experience in the smell.
Old Feb 28, 2005 | 12:08 PM
ALWAZL8's Avatar
The smell went away.... I guess it was nothing.
RevMeHarder
Jun 1, 2026 02:30 PM
DylanForbes
25
Oct 31, 2017 05:47 PM
iphil
Sep 21, 2015 10:49 PM
Forevermore
Sep 20, 2015 01:04 PM
Vedivan1
Sep 18, 2015 12:39 PM
