How low on the marker do you let your oil go before you add a quart?
Old Feb 4, 2005 | 01:55 PM
Imidazole's Avatar
My friends 8 is in the middle between high and low, and mine is 1/4 up from the low marker.
And also, what oil do dealerships put in this? 5w-30? 10w-30? My RX8 and my friends were last done at the dealership, and I'd like to try to stay with the same oil they last did it with - at least the same consistancy.
Old Feb 4, 2005 | 02:30 PM
1.3L's Avatar
Depends on where I'm headed. If I'm just going back and forth to work, I'll let the oil level get down about half way between the high and low marks on the dipstick before adding any oil. If I'm about to head out on a trip I top off the oil regardless of how little it's below the full mark.
I think the recommended oil weight is 5W-20.
1.3L
Old Feb 4, 2005 | 02:34 PM
Vaillant's Avatar
RX-VIII
I believe that from the low mark to the high mark is 1.8 quarts. So, if you are 1/4 up from the low, you could use a quart. Of course, you should probably double check your manual first!
~ Matt
Old Feb 4, 2005 | 02:49 PM
Rhawb's Avatar
Has the whole shit.
I usually throw some in when I'm down to about the last 1/3 of the stick. Seems like a reasonable time to fill it.
Old Feb 4, 2005 | 02:52 PM
Old Rotor's Avatar
I never add oil I just get it changed every 2.5-3k miles. The harder it is driven the more oil you will have to add. It has never got close to the low mark. 20-40 $ is a small price to pay. I have owned many rotarys and love them.
Old Feb 4, 2005 | 03:35 PM
zoom44's Avatar
both cars need oil added
Old Feb 4, 2005 | 03:47 PM
dmp's Avatar
dmp
RX8 and a Truk....
...I take it you keep your oil level to the top of the marks?
Old Feb 4, 2005 | 03:56 PM
Imidazole's Avatar
Hmm... 1 qt each?
Old Feb 4, 2005 | 07:46 PM
Kaliken's Avatar
New AutoX & Track Addict
my oil light pops up at half way.. normally I add about a quarter or a half a quart when it hits that mark.
usually add oil twice between changes. roughly every 800-1K miles.
Old Feb 4, 2005 | 08:00 PM
zoom44's Avatar
they need however much each will take to get them to the full line.
Old Feb 4, 2005 | 08:08 PM
Overport's Avatar
Overport
give it enough oil to satisfy her. fill it up.
uZu
Dec 30, 2015 12:35 PM
Modern2Strokez
Aug 16, 2015 01:07 AM
MatthewRJ
Aug 5, 2015 09:24 AM
RotaryRider
Jul 20, 2015 07:05 AM
