Just noticed they plugged it!!!
Old Jan 29, 2005 | 04:07 PM
midlife crisis's Avatar
Unhappy Just noticed they plugged it!!!
I had the dealer rotate my stock tires the other day and I mentioned a slow leak in one of them. They charged $16 for the rotation and mentioned they repaired the questionable tire. Today I noticed a big ol plug right in the center of the tire. Is this now acceptable on these high speed jobbies or should I raise all sorts of hell?
Les
Old Jan 29, 2005 | 04:14 PM
brothervoodoo's Avatar
RainMan is Back
Not for that rated tire, you shouldn't plug it from the outside. It needs to be done properly from the inside.
Not that I am promoting going above the speed limit, but just say you are doing 110-130mph on the track, imagine the forces being put on that outside plug?
Old Jan 30, 2005 | 11:41 AM
rx8cited's Avatar
Senior Member
You cannot tell by looking at the plug if they plugged it from the outside or used a patch/plug and fixed it from the inside. You have to ask the dealer. If it was patch/pulgged from the inside, it should be fine ........ but not acceptable if plugged from the outside.
uZu
Dec 30, 2015 12:35 PM
hoffdaddy
Sep 6, 2015 11:42 AM
hoffdaddy
Aug 28, 2015 11:15 PM
CMRine04
Jul 29, 2015 02:07 PM
