HELP! - Combustion engine vs. Rotary Engine
Old Jan 26, 2005 | 01:04 PM
Minda's Avatar
Im doing a presentation to my class on a rotary engine and I need the lowdown on the advantages of the rotary engine versus a combustion engine. thanks.
Old Jan 26, 2005 | 01:05 PM
devoid's Avatar
My doctor prescribed RX-8
howstuffworks.com
Old Jan 26, 2005 | 01:09 PM
Minda's Avatar
i know how the rotary works I just hope someone can help me and give a quick summary on the advantages and disadvantages.
Old Jan 26, 2005 | 01:26 PM
Spin9k's Avatar
Momentum Keeps Me Going
Try a Yahoo search on "advantages of rotary engine"
Here's an example of what you'll find:
http://www.monito.com/wankel/advantages.html
Good luck!
Old Jan 26, 2005 | 01:28 PM
trophymaker's Avatar
Advantages:
- extremely smooth, no reciprocating parts
- can rev easily and happily to speeds that exceed most piston engines
Disadvantages:
- not as efficient as its piston counterparts
- little torque output, must rev high to produce power
Old Jan 26, 2005 | 01:43 PM
dmp's Avatar
dmp
RX8 and a Truk....
Rotaries are combustion engines.
Old Jan 26, 2005 | 01:45 PM
SDB's Avatar
SDB
A rotary engine is an internal combustion engine. You probably want to call the project a comparison between a piston engine and a rotary.
Old Jan 26, 2005 | 02:10 PM
124Spider's Avatar
I would add to the advantages that a rotary has fewer moving parts, so (i) it's less complicated, and (ii) theoretically, at least, there are fewer things that can go wrong.
Old Jan 26, 2005 | 04:02 PM
Deslock's Avatar
WWFSMD?
Some already mentioned that the rotary is a combustion engine. Other than www.howstuffworks.com, read through rotarygod's posts here. Also, there's some info in these threads/documents:
https://www.rx8club.com/rx-8-multimedia-photo-gallery-6/ny-autoshow-%93structure-working-principles-rotary-engine%94-handout-955-kb-28125/
http://asmic.com/collect/rotary1999/rotary_e.pdf
In summary, compared to piston engines of similar size and weight
  • rotary engines provide higher power output
  • rotary engines are smoother and have more linear output
  • rotary engines consume more fuel
Because of the poor fuel economy, the rotary is destined to only be used in sports and race cars (in other vehicles, the trade-off is not worthwhile).
The Honda S2000's F20c (4 cylinder 2.0L piston engine) is unusual as it's comparable to the RENESIS in many ways. The S2000 gets 15-20% better fuel economy, but it's slightly heavier and larger and is more expensive to build (getting a piston engine to spin up to 8900 RPM and still be reliable requires finer tolerances) which is partly why the high-power 6MT RX8 can be had for $8k less than the S2000.
Also, due to the smaller number of moving parts, rotary engines are more durable. For example:
Originally Posted by Rotarynews
When the Lola T616 Mazda first took to the track, it featured a modified 13B rotary engine and was rated at 300-horsepower. As with all rotary engines, the T616 lacked the displacement of competitors' engines, but more than made up for this short-coming with incredible, high-revving reliability and the engine's small size and low weight. In the 1984 season, the team went almost a full year without an engine failure, a huge accomplishment, when other teams were rebuilding their engines after each race. The Mazda Lola's engines weren't even cracked open.
globi's Avatar
Also the rotary engine takes less volume (same power and weight) compared to the Otto engine.
You also have to compare it with a 4 cycle piston gas or Otto engine, since a 2 cycle piston gas engine has probably less moving parts and higher power to weight ratio than the rotary or Wankel engine, but also worse emissions.
Old Jan 26, 2005 | 04:14 PM
zoom44's Avatar
Originally Posted by trophymaker
Disadvantages:
depends on the eficiency you are talking about.
mechanically the rotary is more efficient
thermally the piston is more effecient.
Old Jan 26, 2005 | 04:29 PM
124Spider's Avatar
Fuel consumption it's significantly less efficient
Old Jan 26, 2005 | 05:01 PM
RX8Bliss's Avatar
donuts are day old bagels
I'm only posting to say that I'm laughing my *** off at the title. Goodbye.
Old Sep 26, 2008 | 08:37 PM
HockeyRX-8's Avatar
TNC
OMFG! Holy thread revival lol. I'm happy I found this thread because I'm doing the same thing for school and the info in this thread has some good stuff.
Old Sep 27, 2008 | 12:30 AM
8 Maniac's Avatar
Senior Member
I'm glad someone at least pointed out the fact it's a combustion engine. If our cars didn't have a combustion engine, then what's been happening to all that gas I put in? lol
Old Sep 27, 2008 | 02:58 AM
AJ's Shinka's Avatar
Enthusiast
Did the OP get banned for this? I wonder sometimes.
Old Sep 27, 2008 | 03:13 AM
Brettus's Avatar
Boosted Kiwi
nobdy mentioned that the normal engine goes boing boing while the mazda goes
hmmmmmmmmmmm .
Old Sep 27, 2008 | 03:18 AM
hmmmmmmmmmmm .
that explains the tent scene that i have not seen.. but hey i work at disney.. what do i know...
Old Sep 27, 2008 | 09:05 AM
hmmmmmmmmmmm .
~~~~~ boing boing ~~~~~~
Old Sep 27, 2008 | 09:56 AM
NotAPreppie's Avatar
What am I doing here?
No, he got banned for this.
Old Sep 27, 2008 | 10:58 PM
Enthusiast
^^^Good.
Old Jun 24, 2009 | 01:01 AM
zacknolden's Avatar
Originally Posted by Deslock
Some already mentioned that the rotary is a combustion engine. Other than howstuffworks.com, read through rotarygod's posts here. Also, there's some info in these threads/documents:
  • rotary marshall engines provide higher power output
Can you give me another engine which is comparable or better than the Honda S2000's F20c? I don't think I can handle Renesis.
Old Jun 24, 2009 | 02:41 AM
dshiznit1489's Avatar
Formerly Polak Graphics
OP is a ******* idiot.
/thread
1.21 gigawatts!!!
Feb 14, 2019 03:23 AM
Sifu
Aug 30, 2015 10:51 PM
Supernaut6
Aug 11, 2015 07:28 PM
vssystemluba
Jul 19, 2015 04:16 PM
