Repleasement speakers?
Old Jan 25, 2005 | 05:03 PM
modena's Avatar
Modena
Will these speakers fit?
It looks like the rear do but I am unsure about the fronts.
Infinity Kappa 692.5i
6"x9" 2-way car speakers for the rear
http://www.crutchfield.com/S-xZksSiC...asp?I=1086925I
Rockford Fosgate Punch P1682S
6"x8" component speaker system for the front
http://www.crutchfield.com/S-xZksSiC...sp?I=575P1682S
Thanks for any info or comments here....
Attached Thumbnails Repleasement speakers?-ik_rear.jpg   Repleasement speakers?-rf_punch_fron_8x6.jpg
Old Jan 25, 2005 | 05:06 PM
Im_DANomite's Avatar
I love GOOOLD
replacement?
Old Jan 25, 2005 | 05:18 PM
modena's Avatar
Modena
Yeah....
After 30 years in Belgium and 9 in the US, still screw up....
Old Jan 25, 2005 | 06:25 PM
Tamas's Avatar
Registered Lunatic
They will fit - for the front, you may want to look at the Infinity Reference 6800cs. They are cheaper than the Rockford set and appear to have somewhat better parameters as far as sensitivity and frequency response go - however I have not tested either one of these sets so I don't know which one sounds better.
http://www.crutchfield.com/S-RslhYKs...sp?i=1086800CS
Oh, and I think it is needless to say: although Crutchfield has excellent service, price-wise you are usually better off if you search around to buy your stereo stuff
Old Jan 26, 2005 | 07:45 AM
modena's Avatar
Modena
So these drop in for the front and rear?
I have the Bose....
Old Jan 26, 2005 | 10:00 AM
DreRX8's Avatar
uh oh---BOSE :o You may have some compatibility issues. Hopefully someone that has changed out BOSE speakers can chime in--in all my past cars that have had BOSE--replacing the speakers required rewiring the whole system.
Old Jan 26, 2005 | 10:48 AM
mospeed's Avatar
the bose up front are 9". Hence no drop in replacements. I had to make some brackets out of plexi glass to fit my 6.5". Good luck, can be done, but just with a bit of elbow grease.
Old Jan 26, 2005 | 11:56 AM
Tamas's Avatar
Registered Lunatic
I have the Bose....
No, these are drop-in for the base stereo.
The Bose is a different story. The rear size is 6x9 but they have a different impedance than usual aftermarket speakers. I forgot exactly what, but I think they are 2 Ohms or so. If you put in the 6x9 aftermarket speakers, they will work but you might lose some volume, depending on the efficiency of the new speakers. Also, the rear Bose speakers have separate tweeters as well (so they are essentially component speakers).
The front 6x8 is only for the base stereo and a direct drop-in, with no compatibility problems.
With the Bose, you have a shallow 9" midbass driver in the door, and it has some 0.5 Ohm impedance. You won't find a drop-in speaker for that one. If you want to replace it, you'll need an adapter plate and you'll face the same (or worse) compatibility issues like with the rear speakers.
Old Jan 31, 2005 | 01:26 PM
twisty7867's Avatar
For anyone's reference who's doing that in the future, maybe ordering the plastic bracket from the dealer (or a junkyard) -- not sure how much it would cost. The non-Bose models have a big 9" bracket with 6x8 hole in it.
Old Jan 31, 2005 | 02:20 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Excellent explanation Tamas. I have the Bose system and I replace the rear 6x9s with a pair of Infinity 693.5i. The stock speakers have to have a low efficiency, my guess is about 87 dB, I say this because my new speakers are 90db abd they play the same volume as the stock speakers. Every 3db speaker output is doubled for the same amount of power. Did that make any sense?
Jst4fun
Mar 5, 2021 07:16 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Rote8
Sep 22, 2015 03:43 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
