Brakes
Old Jan 22, 2005 | 08:13 PM
oyester's Avatar
sushi lover
Brakes
Hi guys, anybody know what brakes should i get for the 8? Im thinking of getting the brembo brakes (4piston) slotted/drilled...anybody know how much does it cost in AUD dollars? where can i get them in Australia?
Please recommend some brakes that you know which is also as good as brembo? Thanks
Old Jan 22, 2005 | 10:18 PM
Gord96BRG's Avatar
The stock RX-8 brakes.
Seriously - they are excellent brakes, even if they don't have a trendy brand name stamped on them. What exactly do you think is wrong or deficient or lacking with the stock brakes? Excessive stopping distances? Fade? Poor feel? FWIW, the stock brakes seem to excel in all those areas (Short, no fade, great feel). If fade is an issue, then it's the pad material, and a simple change of pads is all that is needed.
Many of the aftermarket kits don't give you a brake system that is as well-balanced as the stock system, so you'll actually end up with longer stopping distances!
Regards,
Gordon
Old Jan 23, 2005 | 01:33 AM
Fanman's Avatar
I have the hawk brake pads & Goodridge brake lines. The biggest difference was the brake lines. If you are looking for Brembos, look at www.mazdatrix.com.
Old Jan 23, 2005 | 11:57 AM
Sputnik's Avatar
First, you need to know (and let us know) why you want a brake kit. Everybody has different wants, needs, and priorities.
-Looks
-Unspring Weight
-Feel
-Performance: Thermal Capacity
-Performance: Braking Effort
---jps
hufflepuff
May 30, 2016 10:45 AM
Road Cone
Nov 6, 2015 01:52 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
