Nav DVD unit manufacturer and questions...
Old Jan 20, 2005 | 02:50 PM
Vaillant's Avatar
RX-VIII
Okay, I just spent a while searching, and I see that the DVD player for the Navigation unit is made by Panasonic. Now, I know I've seen the model number somewhere, but I can't find it. Could someone tell me what it is?
What I'm wondering is if there are any other outputs from the unit. If there are, then possibly the Nav screen could be replaced with a screen that could take that input and a simple video switch could be used to switch between Nav and another desired input.
Any thoughts on this?
Thanks,
~ Matt
Old Jan 20, 2005 | 05:53 PM
truemagellen's Avatar
Attracts tree branches
no there are not any more outputs...they want to kept it OEM/proprietry style (although it is RGBs)...you can get a board that converts RGBs to VGA...but things are going to get complicated and expensive and you'd wish you would have just bought the one they sell at www.rx8garage.net since the Stock screen actually looks great using s-video
we know the unit inside and out...to make things worse it is a pain to remove the factory display...but if you want you can add a touch screen to it if you wish
Old Jan 20, 2005 | 06:00 PM
Vaillant's Avatar
RX-VIII
I've seen the touch screen thing...AntichristPM did it, right? Any idea if a touch screen would work with a modded xbox? This probably isn't the forum to ask about it...
Maybe I'm being cheap (probably), but I sure have trouble paying $450 just so I can get video into a screen that's worth maybe $200.
There are just soooo many things to buy and a fixed amount of $$$, which makes it hard to spend so much on the video input.
~ Matt
Old Jan 20, 2005 | 06:09 PM
unfortunately it won't work with a modded xbox unless you are only running linux...if so then you need the drivers/extensions to use it anyhow
I have a modded xbox as my music/movie/music video/etc. server in the car...I love it!
Old Jan 20, 2005 | 06:14 PM
Vaillant's Avatar
RX-VIII
Yeah, that's what I'm thinking about doing. I'd like to use the stock screen, so it'll be fully integrated, but I may also choose to get a portable DVD player (with inputs) and use that instead. I could then move it from car to car and take it on flights, too.
Just waiting for my tax refund to decide on what to get....
~ Matt
Old Jan 20, 2005 | 06:23 PM
I had two portable dvd players I was using the problem is ground loops...you will have to ground the dvd player to the navigation unit chassis (easiest way is the black ground coming off the nav unit)...one of them looked great but as a portable uinit was a piece of crap for so many reasons...the other one didn't look so good
the xbox is awesome...especially when running XBMC
olyrx7
Oct 26, 2015 09:23 AM
ShellDude
Oct 1, 2015 09:55 PM
FubarI33t
Sep 28, 2015 08:45 PM
Stubbs
Sep 27, 2015 04:06 PM
Digitz0070
Sep 27, 2015 07:49 AM
