dodgy brakessssss
Old Jan 13, 2005 | 04:49 AM
RXXX8's Avatar
dodgy brakessssss
does any elses's brakes squeek? like full on dodgy squeeking that is so excruciating to the naked ear..
like the brakes aren't low or anything they just squeek. i tried getting them de-glazed once and they're squeeking again omggg
Old Jan 13, 2005 | 05:26 AM
sco's Avatar
sco
Could be this issue and fix documented in the US:
http://www.finishlineperformance.com...cs/04-006.html
Old Jan 13, 2005 | 05:43 AM
marigold's Avatar
yep mine squeek too
Old Jan 13, 2005 | 05:48 AM
et381's Avatar
Yeah mine squeek, but only a little. Will get it looked at next service.
Old Jan 13, 2005 | 07:09 AM
RXXX8's Avatar
does the US case apply for Aust too?
Old Jan 13, 2005 | 01:10 PM
timbo's Avatar
rock-->o<--hard place
Only if your brakes are squeeking....
Old Jan 13, 2005 | 02:38 PM
Gibbo's Avatar
In between cars, RX8-less
My brakes were sqeeking very very badly, they de glazed them and it made it go away for about 4 weeks, however the sqeek is starting to come back, but I think new pads and rotors should fix that.
Old Jan 13, 2005 | 06:05 PM
takahashi's Avatar
My brake squeek since i put on the MazdaSpeed brake pads :o
Old Jan 13, 2005 | 06:37 PM
Choppy's Avatar
www.rx8club.com.au
Yeah mine are squeeking too.. really faint though enough to bring them to Ezzy's attention who informed me of it.
Old Jan 13, 2005 | 07:07 PM
labrat's Avatar
Mine don't squeek. Could the problem be due to travelling on roads where there is a lot of oil dumped, or have very soft tar, or indeed where there is a lot of diesel exhaust emitted close to the ground? Glazing could be due to deposition of oily crud which subsequently oxidizes, or to deposition of the binding material used in the brake pads. The squeek is made by a high frequency slip-grip action of the pad on the disk.
I know my discs rust very quickly. I get a light yellow film within minutes of the discs getting wet - it looks like the iron mineral goethite. However, it polishes off with the first light brake application
Old Jan 13, 2005 | 07:27 PM
timbo's Avatar
I agree it has to do with driving conditions. Mine have squeeked a bit when I spent an extensive period where my daily driving was Sydney peak hour traffic. But once I got back to a more regular, higher speed, less stop-start drive, it disappeared.
Old Jan 14, 2005 | 02:00 AM
mikeyr's Avatar
i need a new photo
Ditto, only when there is lotsa peak driving, ususally flames off pretty quickly with a cruise.
Old Jan 14, 2005 | 02:29 AM
RXE16T's Avatar
'RX-EIGHT'
Mine used to squeek as well when I used to spend a fair bit of time in peak hour traffic.
It's a lot better these days since I use the back streets to get to work and the traffic flow is continuous.
Old Jan 14, 2005 | 03:20 AM
Hymee's Avatar
Race Steward
ROFLMAO!!!! Quip of the day!
Cheers,
Hymee.
Old Jan 14, 2005 | 03:22 AM
Hymee's Avatar
Race Steward
Wow - a chemisty and a metalurgy lesson in one!!!
Mine used to squeel a little. I don't remember when they stopped squeeking. Maybe one of the braking areas fixed it.
Cheers,
Hymee.
Old Jan 15, 2005 | 01:44 AM
mikeyr's Avatar
i need a new photo
Talking
Cheers,
Hymee.
Or the mouse escaped !
Old Jan 15, 2005 | 03:50 AM
Hymee's Avatar
Race Steward
Actually, I applies some teflon to the rotors
Cheers,
Hymee.
Old Jan 16, 2005 | 12:45 AM
timbo's Avatar
Actually, I applies some teflon to the rotors .
Yeah, I've tried that, too. How do you get the frikin' stuff to stay on, though?
Old Feb 8, 2005 | 10:34 PM
Jambos's Avatar
Had the 10,000k service done Friday, told the service guy that I had some intermittent squealing from the brakes, they degalzed pads and dedusted the rotors, driving home brakes still squealing.
Rang service guy today and quoted the American Mazda service bulletin re brake pad replacement, he rang Mazda and yes they are going to replace my pads under warranty.
I believe they will replace pads over 4mm wear, if you have Squealing brakes.
Old Feb 8, 2005 | 10:51 PM
Gomez's Avatar
Shifty Bastard.
Blue cars don't squeak .
Old Feb 8, 2005 | 11:04 PM
takahashi's Avatar
Same as black.
Old Feb 8, 2005 | 11:26 PM
timbo's Avatar
C'mon guys ... you are forgetting labrat's technical explanation, which clearly shows car colour has nothing to do with it
BTW, mine's VelRed (the fasta one ) and has never squeaked
Old Feb 9, 2005 | 07:13 AM
Gomez's Avatar
Shifty Bastard.
Cheers,
Hymee.
When someone plows into the back of your car during the next cruise, don't come crying to me buddy :D .
Old Feb 9, 2005 | 06:25 PM
skc's Avatar
skc
rev it up
I have really bad squeal from my brakes. My dealer told me that they did not notice any thing. It happens under moderately hard braking....so they may not have been able to induce a squeal.
Now that a dealer has accepted responsibility to fix the issue it may be worthwhile trying again.
Does anyone know if this recall fix actually works?
skc
Old Feb 9, 2005 | 09:59 PM
azzaboynt's Avatar
apply generous amount of lubricant... ONLY JOKING! :D
So when you are crusing, you ummmm... don't use the brakes, and therefore they erm... don't squeek as much? Hmmm....
