Tire Pressure light on-don't have option
Old Jan 10, 2005 | 10:13 AM
Frank Patrick's Avatar
Help- All of sudden I am getting a TP dash indicator00 I don't even have TPS on the car--any clues- to shut it off?
Old Jan 10, 2005 | 10:29 AM
expo1's Avatar
He's as bad as Can
Thought TPMS was STANDARD on all US spec RX-8s.
If you did not have TPMS you would not have a working TPMS light. I would go out and check the air in your tires.
Old Jan 10, 2005 | 10:36 AM
SlashMatrix's Avatar
Actually i had the same problem. My light was comming so i checked my lights and 1 tire was at 29 psi instead of 30psi. So i put more air in that one but it did the same thing a week later with even psi. I took it to my dealer and they did something to the computer and drive it for a minute to see if it came back on. it didn't so i guess they fixed the problem. Or atleast the light didn't come on anymore. I havn't checked my tires recently. Maybe they just turned the whole thing off.
Old Jan 10, 2005 | 12:02 PM
tps-plus rain
this happened once before- common element- appears to be rain- I checked TP digitally all at 30 psi- I'd just like to turn the whole thing off- at this point
Old Jan 10, 2005 | 12:08 PM
zoom44's Avatar
all us cars have the tpms. check you tires cold then bring them all to 32psi.
Old Jan 10, 2005 | 12:22 PM
Ok- you all where correct - I do have them- thanks- I just heard from dealer- he said my lap-top- which I run periodically from car is setting off the sensors- (not sure I'm buying this) I asked why is this only happening when it rains- He said not sure- How many have disconnected this little gem?
Old Jan 10, 2005 | 12:40 PM
expo1's Avatar
He's as bad as Can
That is a good one!! Lap-top sets off TPMS :D
As for turning off the TPMS, you can't.
Old Jan 10, 2005 | 01:09 PM
gotta be a way!!
With all of the smart folks on this forum there has to be a simple way to make this "pain in the a-- light" go-away/ disconnected- other then the seemingly complicated procedure one member-has already published- There is more and more posts relative to this issue, makes you wonder if the TPS might be showing signs-(maybe age/milage etc.) that this little feature is not the most robust instrument on the car.
Old Jan 10, 2005 | 01:16 PM
zoom44's Avatar
yes they are susceptible to interference(its in the manual) from some electronics. check with MazdaManiac. he found the wire to clip to shut it off.
Old Jan 10, 2005 | 01:46 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-disabling-tpms-35708/
Old Jan 10, 2005 | 01:59 PM
expo1's Avatar
He's as bad as Can
Of the three pages in the above "DIY" MazdaManiac ( thread starter) is the only "success" story.
Old Jan 10, 2005 | 02:31 PM
Thanks Folks
I'm going with a little snip to that wire!!
drebbrnator
Dec 27, 2018 07:02 PM
05TiGr8Lady
Aug 27, 2015 07:31 PM
talonhart2
Aug 26, 2015 04:14 PM
MolecularConcept
Jul 26, 2015 09:09 PM
