Deleting destinations on the OEM Nav.
Old Jan 4, 2005 | 10:52 PM
ssjelite23's Avatar
Maybe next lifetime...
Question Deleting destinations on the OEM Nav.
Does anyone know how to delete the history destinations from the OEM Nav?
For example when you input a destination in and have no use for that destination any longer.
I tried scrolling through the menu options but couldn't find one that says "delete" to remove the old destinations I have.
Old Jan 4, 2005 | 11:00 PM
mysql101's Avatar
i haven't done it in a while, but try going to the screen that lets you edit the name, icon, etc for the location, I think it also has a delete option.
Old Jan 5, 2005 | 07:30 AM
8's enough's Avatar
when you go to menu go to histiory then click on a location you have been .then double clik on that location then a screen appears where you can delete.
Old Jan 5, 2005 | 03:10 PM
Vaillant's Avatar
RX-VIII
It took me a while to figure out how to delete marked points.
You have to go to the setup menu and go to edit marked points. Then, not only can you delete them, you can rename them. Basically what Jason said, but to get there you need to go to the setup menu.
For locations in your history, I'm not sure.
~ Matt
Old Jan 5, 2005 | 05:00 PM
Vaillant's Avatar
RX-VIII
Nah, you don't need to. Not to edit or delete marked points...and I don't think for the history either.
The cool thing is when you edit a marked point name, the name shows up on the map screen at the marked point location.
Old Jan 5, 2005 | 05:19 PM
mysql101's Avatar
There is no need to access secret menus to delete.
Old Jan 7, 2005 | 12:53 AM
ssjelite23's Avatar
ah, thanks guys. Now that you guys have mentioned it, I do recall seeing something in the section where you can rename the destinations. I'll try that tonight.
I need to delete all the nudie bar destinations, need room for more...hehe :D :D :D
thanks again fellas!!! good lookin' out!!!
Old Jan 7, 2005 | 08:40 PM
ssjelite23's Avatar
I tried it and it's actually for marked points only. for the history section, still can't figure out how to delete. I tried the "double click" thing that didnt' work either. I may have to see about that "secret menu", haven't tried that.
any other suggestions?
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
arexatemate
Nov 7, 2015 02:27 PM
Quiggs321
Sep 30, 2015 05:34 PM
