Help, 1st oil change, could not find the crusher
Old Jan 3, 2005 | 07:17 PM
TY_888's Avatar
1 st oil change, slowly unscrew the plug, in particular, I want to reuse the crusher, but there is no crusher? where is it? is it possible they forgot at factory?
I am going back to garage to see if the oil stop dripping, may be it stuck to the pan
Old Jan 3, 2005 | 07:42 PM
czr's Avatar
czr
RX8 RX8!
There definately is a washer. I've changed my oil twice and it's been there both times. You're right.. Maybe it's in the oil pan.
Old Jan 3, 2005 | 08:17 PM
TY_888's Avatar
I went back to check the oil pan, no it is not there. The drain hole is clean and no crusher attached to the drain hole. Put my hand in the oil and nothing inside the old oil.
I am positive there is no crusher. When I unscrew the plug, I did it so slowly and use the finger feel the crusher, but it is not there.
I've got 2 new crushers from dealer last month, I am going to put the new crusher. I feel the drain hole again to make sure I will not double up the crusher.
I picked up the car new. May be the dealer prepare the car for delievery or during transport, they flooded the engine, so they change the oil without putting the crusher back. How should I know? Well, I am stock up the crusher and do the oil change myself.
Old Jan 3, 2005 | 08:43 PM
bryrx804's Avatar
What the hell did you just say.. =) lol
Lost me on I went back..
Old Jan 3, 2005 | 11:19 PM
RotaryNoob's Avatar
Hi
Mine didn't have one either and it doesn't leak, my last car didn't have one and I never put one on and after 100K it still didn't leak.
Old Jan 3, 2005 | 11:31 PM
Nubo's Avatar
Lubricious
Swirling your hand in the oil doesn't necessarily find it. This has happened to me several times and I find the thing in the drain pan after transferring the oil into a larger container for storage. Sometimes it gets caught by the funnel and sometimes it sticks to the pan and I find it once the oil is gone.
The other place it can "hide" is on the drain plug itself. Using a nice bright light you might be surprised to find it stuck to the flange of the plug so tightly that it looks like part of the plug.
Old Jan 4, 2005 | 12:06 AM
TY_888's Avatar
I am positive, no crusher. I poured the old oil back to the empty container. No crusher in the funnel or the drain pan. Like I said, I was looking to get the crusher when I unscrew the plug.
Double check the plug/ the hole, nothing. I put a new crusher and tightened up the drain plug, changed the filter and refilled with new oil. And I could not believe it took 4.3 litre. And the manual stated 3.5 litre. Better go with the dipstick marker. Right at the full mark.
Well, I do not know where and how the crusher disappeared?
Old Jan 4, 2005 | 03:51 PM
Crichton's Avatar
I would agree with this. When I first changed my oil, I couldn't find my crush washer. I looked everywhere and finally looked at the plug itself. I was basically "sealed" to the plug and I had to knock it on the ground to get it to separate.
Skyl3r
Dec 2, 2019 04:51 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
BigMikeATL
May 26, 2016 12:31 AM
RotaryRider
Jul 20, 2015 07:05 AM
