CZ and Cruize control
Old Jan 1, 2005 | 01:29 PM
I found out something interesting today on my highway drive to Pullalup.
When you are in cruise control....the E-manage reads a throttle position of zero the way the CZ is set up.
This causes the car to run in a static position on the map. At 75MPH its at 0TP and 3900ish box in 6th gear. This isn't a problem at this point per say....as it is in closed loop. The problem is when you are going 77+mph....depending on the load....it will switch into open loop mode, and run rich (about 14.0ish). What I did was put a -4 value in the box ( not used for much else, as 0TP and >idle is off load anyway) so that it will run stoich.
I talked to Dan Harrison, and am trying to get him to add the open/closed loop indicator to the loggable values. Will make it easier to figure out when this thing wants to run in open loop.
I've altered a lot more of my parial throttle values on the A/F map, as it goes into open loop a lot more than not over 5K RPM and over 20%throttle
I have a few spots that it is still adjusting closed loop a bit, because it alters my fuel trims a bit driving around town....doesn't seem to be a problem though.
pjwermuth
Sep 28, 2015 11:36 PM
Wurromurro
Sep 20, 2015 05:02 PM
yankeepicker
Sep 11, 2015 05:42 PM
