With spring around the corner, thinking about new wheels ...
Old Dec 25, 2004 | 03:13 PM
draco067's Avatar
Cap'n Limekitten says arr
and I had a question
Everyone always asks "will such and such tire fit my wheel", so I'm gonna flip it around. What range of wheel widths will the stock Potenzas fit? I'm guessing I could go to 18x7.5 with no problem, but what about 8.5?
And someone please correct me if I'm wrong, but the stock wheels are 18x8, +42mm, and 5x114.3?
Old Dec 25, 2004 | 08:51 PM
18X8J +50 offset 5X 114.3
Old Dec 25, 2004 | 09:55 PM
draco067's Avatar
Thanks for the correct offset.
ok time for newbie questions
Less offset means the wheels stick out more, correct?
If I get a wheel of a different width, say 7.5 instead of 8, will the same offset work or will it need to be bigger/smaller? (ie what would be a good offset for a stock-ish fitment of a 7.5 wheel?)
Old Dec 25, 2004 | 10:16 PM
Sociopath's Avatar
SocioPath
Smaller offset number means the wheel would stick out more. With 7.5" width wheel, you're looking at a +35 offset to give it a more "flush" look against the car.
Old Dec 25, 2004 | 10:30 PM
try out : http://toy4two.home.mindspring.com/offset.html
will answer most of your questions.....
Old Dec 27, 2004 | 06:12 AM
draco067's Avatar
Thanks that's a great page.
Although I'd still like to know if the stock Potenza's will fit on a narrower wheel (7.5") - my gut feeling is yes, since 1/2" is only about 12mm, or 6mm extra per side that the tire would extend over the stock wheels (and we all know how far (not) the stock tires stick out).
Old Dec 28, 2004 | 01:08 PM
draco067's Avatar
And while I'm at it - will the stock potenza's (or any 225 tire, for that matter) fit on a 8.5" wheel?
Old Dec 28, 2004 | 03:29 PM
draco067's Avatar
Alright, I've narrowed my choices down - anyone see any obvious problems with getting 18x7.5, 5x114.3, +43mm wheels and using stock tires? If I did it right, the wheels stick out like 1mm more than stock, and the tires should fit nicely too.
Old Dec 29, 2004 | 09:55 AM
draco067's Avatar
ok I talked to someone at discount tire direct, and I'm lost
if a 245/40/18 will fit on a stock 18x8 (which he confirmed), why won't a 235/40/18 fit on a 18x7.5?
10mm is about 1/2" (I know, 1/2" = 12 point something mm, but it's 2mm!) so I'd think it would be ok, but they said no.
Billy Marcial
Mar 1, 2018 06:50 AM
WingleBeast
22
May 23, 2016 09:22 PM
D13
Aug 22, 2015 11:42 PM
Kahl
Aug 20, 2015 11:49 PM
Jazzmeson
Jul 31, 2015 01:47 AM
