Identifying trans & diff crush washers
Old Dec 24, 2004 | 10:07 AM
beachdog's Avatar
I just received my redline fluids and crush washers from one of the forum sponsors. I ordered a total of 4 crush washers which came unlabled in a bag. There are two of each kind. All aluminum in color. All the same inner and outer diameters. The only difference is a slight difference in thickness.
So, where do the thick and thin ones go?
I'm assuming that I won't be able to tell much from the old ones since they will already be crushed. Without additional guidance, my inclination would be to use the thicker ones for the drains and the thinner ones for the fills.
Any help would be appreciated.
Old Dec 24, 2004 | 10:35 AM
expo1's Avatar
He's as bad as Can
These threads should help
https://www.rx8club.com/series-i-tech-garage-22/clarification-manual-trans-differential-crush-washers-part-numbers-44584/
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-transmission-differential-fluid-replacement-35115/
Old Dec 24, 2004 | 11:02 AM
beachdog's Avatar
Thanks, expo.
I had already reviewed these a while back, probably before the part number corrections so I don't have the copper one for the diff.
JD's website did answer the question that the trans washers are the thicker ones.
Old Dec 24, 2004 | 11:10 AM
expo1's Avatar
He's as bad as Can
I just reused the copper one when I did my fluid change. It's the filler plug so what really can go wrong?
Old Dec 25, 2004 | 12:28 PM
rx8cited's Avatar
Senior Member
Leaks when taking corners or on inclines? Most likely not going to happen if you torqued the plug to spec. and this the washer's second use.
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
bosstin87
Oct 5, 2015 06:52 AM
XianUnix
Sep 29, 2015 03:48 PM
