Resetting E-Shaft Plate for exhaust install
Old Dec 24, 2004 | 06:44 AM
RX-Nut's Avatar
8 the HARD way.
Is it required to do the 20 brake pump (reset PCM, eshaft thingy) after an install of an aftermarket exhaust?
Old Dec 24, 2004 | 09:44 AM
mysql101's Avatar
can't hurt.
Old Dec 24, 2004 | 10:05 AM
philodox's Avatar
Rangers Lead The Way!
Originally Posted by JasonHamilton
can't hurt.
I 2nd that motion..
Old Dec 24, 2004 | 10:52 AM
MazdaManiac's Avatar
Better yet, do the "hold down the odometer reset while you turn the key to on without starting the motor and continue to hold until you see the word TEST and then repeat two more times" thing.
Then do the 30 stomps....:D
Old Dec 24, 2004 | 10:58 AM
expo1's Avatar
He's as bad as Can
Never read about that one, what does that do?
Old Dec 24, 2004 | 05:29 PM
RX-Nut's Avatar
8 the HARD way.
Hmm.. you messing with me arent ya..
How many here have done the stomp reset after an exhaust install?
Old Dec 24, 2004 | 05:43 PM
Not at all.
It does a complete PCM reset without loosing your radio presets.
Old Dec 24, 2004 | 07:24 PM
RX-Nut's Avatar
8 the HARD way.
Hmmm.. is this safe? Where will TEST appear?
Sorry, just skeptic since I havent read it before.. thanks!
Old Dec 24, 2004 | 08:56 PM
The word "test" will appear in your odometer. It is a gauge cluster/ECU diagnostic mode.
If you do it three times in a row, it clears the entire PCM adaptive profile.
Old Dec 28, 2004 | 09:37 AM
mysql101's Avatar
MazdaManiac, thanks for that tip. It must reset more than the brake stomp reset since I had a low power issue that was only able to be resolved with the test method (brake stomp didn't do squat)
Old Dec 28, 2004 | 06:35 PM
theCATALYST's Avatar
In darkness I sleep.
I never did a stomp or any kind of reset after I installed my Greddy. Should I be worried? Car has been parked two weeks now at the heliport. I only drove it that day for several hours.??
Old Mar 20, 2015 | 10:28 PM
chavostrong's Avatar
Genius may have solved my problem..shall try this in the morning. Didn't know Mazda had this trick. Used it on american brand vehicles. And thought since rx8 is special its all electric Like needing a computer. Glad I keeped searching
Old Mar 20, 2015 | 11:46 PM
wow, this must be a new record .....
talonhart2
Aug 26, 2015 04:14 PM
yapakanichi
Aug 25, 2015 01:24 PM
MarkX
Jul 31, 2015 07:50 AM
AussieGray
Jul 16, 2015 03:58 AM
