Question about exhaust controller...
Old Dec 20, 2004 | 01:31 AM
trophymaker's Avatar
If I got a midpipe, but wanted to be stealth most of the time, would this exhaust controller be appropriate?
Or would this bypass the exhaust system altogether and dump straight to atmosphere?
Thanks.
Old Dec 20, 2004 | 02:31 AM
rotarygod's Avatar
Exhaust controller? You're going to have to post a link to that one.
Old Dec 20, 2004 | 02:57 AM
RXE16T's Avatar
'RX-EIGHT'
I'm in the same boat as RG on this one...... pics? links?
Old Dec 20, 2004 | 06:04 AM
draco067's Avatar
Cap'n Limekitten says arr
exhaust cutout maybe?
Old Dec 20, 2004 | 06:38 AM
magixpuma's Avatar
Basically its a electrically controlled butterfly valve that can be open 100 percent - or you can close it to as much as you want like \ |
Old Dec 20, 2004 | 06:40 AM
magixpuma's Avatar
http://f2.autospeed.com/cms/A_2291/article.html
Old Dec 20, 2004 | 06:43 AM
expo1's Avatar
He's as bad as Can
Or like this system
http://www.superstang.com/powered_exhaust.htm
Old Dec 20, 2004 | 08:28 AM
My apologies, I thought it was a common thing...
Here is where I discovered it...
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Dec 20, 2004 | 08:42 AM
expo1's Avatar
He's as bad as Can
I would be VERY leery of any performance MOD listed on Ebay. The motor for the Butterfly would be very close to the exhaust pipe in the Ebay item. RX-8 exhaust gets VERY HOT, could burn out the motor in that very fast. You also need to factor into that the cost of the custom exhaust work, cutting out a section of pipe and adding the bypass section. As stated many times before here Mazda put on a pretty good exhaust system (power wise) so other than noise power gains would not be very noticeable.
Old Dec 20, 2004 | 11:37 AM
alnielsen's Avatar
And the noise from an unmuffled rotory engine is so loud it can cause deafness. IMSA use to allow the RX3's and RX7's to run open exhaust in the late 70's. It was painful to listen to the cars as they went by.
Old Dec 20, 2004 | 11:40 AM
therm8's Avatar
Bummed, but bring on OU!
It's not a performance mod, it's a "My exhaust is so loud, people on Harley's stay away from me, I need something to quiet this thing down so I don't break the neighbor's windows every time I come in at night" mod. Looks like an adjustable solenoid, and not a motor. Solenoids are pretty durable and get very hot themselves when energized.
Old Dec 20, 2004 | 01:33 PM
Hmmm I was thinking there was some way to rig something like this to breathe thru a testpipe when i wanted, and a stock cat otherwise... I guess the room underneath the car, and the cost/complexity might not be worth it?
Old Dec 21, 2004 | 01:01 PM
rotarygod's Avatar
The difference between a stock cat and a straight pipe is only about 7 hp or so. That is alot of effort for something you won't feel.
Old Dec 21, 2004 | 01:14 PM
I was speaking in terms of sound, not performance. There would be sometimes that I would want very loud exhaust, and then sometimes I would want to be stealth... just trying to envision I could have these things with the push of a button!
Crap.
Old Dec 21, 2004 | 03:03 PM
rotarygod's Avatar
A butterfly valve inline in the exhaust system wil definitely control noise a little. More importantly it will control the amound of flow through the exhaust. This can affect your powerband. The Australian one in the link above has a controler that can be dialed in. This may do a little bit for low and midrange power but it also keeps the car quieter until you really get on the gas. You would defintily want a different, louder muffler in conjunction with this. It could work really good. It's good in theory. Try it out and let us know how you like it.
SupraG
Sep 21, 2015 12:09 AM
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
badinfluence
Series II Aftermarket Performance Modifications
Aug 31, 2015 11:51 AM
dancingdan42
Aug 19, 2015 09:29 AM
yapakanichi
16
Jul 28, 2015 03:44 PM
