subduedracer
12-17-2004, 08:56 AM
I get out to my car this morning. I started her up as normally I do. I then notice that the radio buttons don't work. The a/c heater control doesn't work, the amp temp display doesn't work. However, the radio buttons on the steering wheel work. I checked the fuses and nothing blown. WTF?
Spyder_doo
12-17-2004, 09:27 AM
I know I got in my 8 the other morning when it hit below freezing and the lcd display kinda of hesitated. The changing from one letter or number was very slow. I dont know what was wrong, but it cleared up and was normal as soon as it became warm in the car.
Jamie
bigblockbeater
12-17-2004, 09:49 AM
oh no! not you too! first question i have to ask, did you alter the stereo in any way? install any aftermarket parts to it? i put a line rca adapter on mine and now only the fan and hazards work. mazda told me i broke it so i am screwed. mine is the basic stereo. if you didn't touch the stereo then take it to your dealer and have them replace it. there are no fuses burned. the unit itself is the problem. good luck
It's probably a loose connection in the rear that controls both radio/ac etc. If you didn't change anything, you can take it to the dealer or try to check the connections yourself as it doesn't take more than 45 mins but that gold screw is a pain.
buzzardsluck
12-17-2004, 11:45 AM
i dont know if this is right but the same problem happened on my truck. on my truck the problem was the modules that the knobs are attached to. i had this problem after i had replaced a cd player. if this is the problem they are an ez fix. if this sounds dumb just ignore me lol
subduedracer
12-17-2004, 05:18 PM
I went out to my car later today, and its working. I think this is going to be an intermentant problem.
04-Rx8
02-28-2010, 03:51 AM
My radio won't come on, aswell as the heater controls, just the fan and temp will work. How do I fix the problem.
