View Full Version : xpel
mazdaexe
05-20-2003, 07:42 PM
Anyone tried using xpel on their car? My current car has tons of rock chips and I really dont want that to happen on the 8 (especially when its black). Or any recommendations on similar products?
Thanx for any feedback
Fd3BOOST
05-25-2003, 10:57 AM
I've never heard of it, do you have a link?
mazdaexe
05-25-2003, 12:43 PM
http://www.xpel.com
http://www.invinca-sheild.com (http://http://www.invinca-sheild.com)
Basically, they are like very thin plastic where you can stick to your hood and bumpers to protect the paint. Just wanted some feedback and see did anybody on the forum ever used similar products.
IGOZMZM
06-20-2003, 01:26 AM
There is a Utah company that claims a better product than those listed. They use 12 mil product and the xpel company only uses 8 mil. Also everything Clearbra does is custom made for each vehicle (or whatever you want protected). They can also protect the front, rear or the entire car if your that paraniod :D
Take it for what it's worth, I'm just adding options keeping the thread on topic :) and NO I don't work for the company.
Clearbra (http://www.clearbra.net)
mazdaexe
06-20-2003, 03:11 PM
Thanx IGOZMZM for the info, but I live in CA, and I dont think they have a dealership in CA. And it seems the custom install cost alot more. I think xpel charges around $200 for the front + installation
Hercules
06-20-2003, 03:18 PM
In 5 years of owning my car, I've gotten a negligble amount of rock chips.
Thus, I'm not going to get any protection for my car in that regard. Since I'm leasing anyway, there is some understood wear-and-tear that will be accumulated when I return the car, and otherwise it will be in pristine condition, so...
No clearbra for me :)
Invisiguard
08-01-2003, 01:19 AM
The Xpel pattern for the RX-8 is available from any Xpel dealer for those interested, check their site for a dealer finder by Zip code, Xpel.com
As for the thickness of the material, Xpel kits can be cut out in any thickness, typically though, 8mil is the perfect compromise for protection versus visual obtrusivness. We will use 12 mil on some custom race applications but 8 mil is more than enough to stop the chips, scratches, and sandblasting that occurs on streets and highways, check the pic to see just how tough 8 mil is. Also, the company you are refering to "Clear Bra" still uses vinyl film. While vinly film is less expensive than 3M urethane films, vinyl has less stable plasticisers than urethane and therefore evaporates at a faster rate than urethane. If you have ever seen an old convertable top back window that is yellow, hardened and cracked, you know what it looks like when vinyl plasticisers evaporate. Most all other reputable kit manufacturers like Xpel, Stonegard, and Dynashield use only urethane films, make sure your installer does too.
Jeremy
red_base 95
08-01-2003, 09:31 AM
Judging from that pic, the film looks rather opaque. The fingers behind the film are defitely not as clear as I would like. Perhaps that changes when applied?
Also curious, how would you repair the film if it becomes damaged? And does dirt, wax, etc. build up at the edge of the film if an entire panel is not covered?
Seems like it would prevent a lot of the everyday scratches and nicks, but how about the dreaded runaway shopping cart?
Invisiguard
08-01-2003, 10:29 PM
The urethane film has a presure sensitive adhesive backing, this is what apears opaque, once it is applied it is completely transparent, this film would not be of much use if it turned the entire area it covered foggy;) see the pic for an example off the clarity. The film is thin enough that any dirt/wax build-up along the edges is easily wiped away with a towel or brushed out, a medium bristle tooth brush works well. This film provides protection equal to or better than a traditional vinyl car bra, typically this means only impacts large cause a dent in your car may penetrate the film.
Invisiguard
08-01-2003, 10:35 PM
hey! how about that pic!:D
PoLaK
08-02-2003, 01:09 AM
Is it Wax-able?......... what happens if it rippes or if you get tired of it and want it off will it ruin the paint finish?
mac
08-02-2003, 01:40 AM
I've read that it comes off if you heat it up at 158F and peel off without damaging your paint. What I want to know is will there be discolouration?
colin204
08-04-2003, 02:26 PM
having it installed today, let you guys know how it turns out.
Evil Weevil
08-08-2003, 08:22 AM
hey, colin... how does it look then ?
colin204
08-09-2003, 10:43 PM
hood and fenders look great, the installer is redoing the bumper, he says it will be perfect when done. It is a 5 on 1-5 scale for dificulty and the installer says it takes putting one on to learn the tricks for the specific car. I am not to worried because I saw a 350z the installer did and it looked great.
Evil Weevil
08-10-2003, 05:02 AM
Don't forget to post us all some pics when it's done! I'm not surprised it's difficult on the front - there's so many curves to it!
jerzeydevil
08-13-2003, 11:22 AM
colin....any pics of this installed yet? anxiously waiting...thx
colin204
08-14-2003, 08:18 PM
got the front bumper redone, looks great, will post up some pics tomorrow after I wash the car.
Invisiguard
08-20-2003, 01:38 AM
You can wax the film with anything you would normaly put on your car, we usually recommend Zaino or other polymer waxes since they dry clear and do not leave a noticeable build up along edges. Also, though meant to be a permanent installation, the film can be removed at any time with no damage to the paint, and since the film is clear, and it will allow the paints color to depricialte evenly.
Jeremy
ZoominRex
08-26-2003, 08:48 PM
How much does installation typically run for both the hood and bumper kit? I called an installer today in my area and he wanted about 450 just for the install!!! That brings the total to about 1000 dollars which takes it way out of my price range. I have other areas to put 1 G in...like suspension. Otherwise it looks like a great product. Looks like I'll have to break out the saran wrap. :D :D :D
Invisiguard
08-26-2003, 09:05 PM
You should be able to get it done for much less than that.
tpryor
08-27-2003, 08:49 AM
My yellow one was done for $600, including installation (all the xpel kits except the door edge guards). Pics, before and after, are at the link in my signature block.
I am VERY happy with how it looks and protects. Also, it now has two coats of Zaino (car already had three when applied), and it's as "slick" as the rest of the car.
JVSpiller
09-03-2003, 10:48 AM
Jeremy
Can the entire hood be done or does it have to be just the front 12" or so. I'm concerned about the line.
tpryor
09-03-2003, 11:09 AM
There is a line, and you can see it IF you are looking (and better in the shade). But to give you an idea of how hard it is to see, the dealer has had my car twice (wheels and removing the OEM oil filter), and until the tint guy walked by and noticed it (on the second trip), they had no idea it was on there.
Come by the Houston "get together" on the 21st, mine will be there and you can see for yourself.
It is WAY better than rock chips OR a "regular" bra, which would have BIG black lines AND damage the paint if not removed and reinstalled constantly......
AND, they can cut any size piece you want, but the hood would be very difficult to do with the rotor shaped indent.
JVSpiller
09-20-2003, 02:29 PM
I had cleartech pro install my clear bra yesterday and I'm concerned about the amount of areas where the texture appears to be affected by stretching or heating during the application. The simple areas like the hood and front part of the quarter panels look great, but it does not look good anywhere the body has a curve like around the grill and on transitions around the lights. Is this normal or should I have it removed and re-applied?
JVSpiller
09-20-2003, 02:31 PM
Another shot of problem area
mikeb
09-20-2003, 04:49 PM
I dont have the clear bra but I've seen about 3 applications on the 8 and yours looks like there's
It looks fine
emailists
09-28-2003, 07:31 PM
search for my 3M thread- many pics- 2 things - the installer told me that it takes some time for water to evaporate from under the film, so even though I had one area on the rear quarter panel that had a big bubble of water trapped there, it went away after a few weeks (air will not though) It's hard to tell from your pics, but honestly I do not think it looks very good. My install looked much better even teh same day- very little texture, and your seems to have tons of trapped water or air pockets? maybe it's the pic. The 3M material should have almost no texture at all when done- maybe I can see some when loooking at a reflection of a light in the surface. I had the X-pel kit done. see my posts
spdspappy
09-30-2003, 10:53 PM
Does anyone know if you can/should use something like zaino b4 you have xpel (or equiv) put on the car?
JVSpiller
10-01-2003, 01:41 AM
Any good applicator will remove all polish from the car through a combination of clay bar and light stripper before installing the X-Pel. I zaino'd mine before the installation with no issue.
Omicron
10-15-2003, 04:50 PM
I made an initial inquiry into this the other day, and was told it would have to be put on in multiple pieces due to all the curves. Colin and anyone else who's had this done, can you tell me how many pieces it went on in?
Thanks...
Invisiguard
10-15-2003, 05:06 PM
this is the Xpel kit for the RX8, every body panel gets one piece, if your installer is cutting it into multiple pieces he is not installing it correctly, BTW, the those two parts below the bumper opening but together when installed.
CoastalKT
12-26-2003, 10:39 AM
I live in MD, BWI area, and I am pricing Xpel, or other like products, for my 8.
Can anyone recommend good installers (with reasonable prices) in MD (or maybe N. VA)?
I have seen one post that said $600 but the location was Texas...
Many thanks !
Invisiguard
12-29-2003, 02:58 AM
the only one out your way I know does good installs is Rob at MD performance 410-750-8370, he is a bit pricey but everyone we have sent out his way has been completely satisfied, tell him Jeremy from Invisiguard sent you, also tell him you will put in a good word for him on the board, he should show ya some consideration
